KLEEMANN W203K Alloy Pulley
Former Vendor of MBWorld
MBWorld.org Members:
The KLEEMANN Alloy pulley for M111 eninges (W203 Kompressor Coupe, other chassis build date > 7/00) is now available.
EvoSport has a special offer for you. Place your order with EvoSPort before July 12th and recieve the system for $799 (regularly $899).
2002 Paprika C230K/C7/C4/C2/6spd/Chip(?)
Originally posted by Buellwinkle
Looks different than the original pulley you showed us before. I guess you decided to go with a steel band where the pulley rubs against the seal like the ASP pulley. I didn't care for the old design myself. All I can say about your pulley is it's ugly, too many holes (LOL!).
Originally posted by KLEEMANN
Ummm, Yeah, right- the steel band has always been there. This is the same pulley I posted pictures of several months ago- I thought you had a sharp eye?
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
OK, then just maybe I misunderstood when you posted this as representation of your alloy pulley in the making. This looks like a steel cylinder pressed into the pulley and not a band.
Dead eye
Buell-
That picture is of an alloy pulley- taken at an angle in light conditions where the steel oil seal sleeve is picking up the body color of the pulley- Check it against the new pics (of the same pulley) you can even match the PN. Notice the seam on the hub plane- its a sleeve.
Our pulleys are made by one of ASP's biggest rivals (notice how I didnt say competitor) they have been making pulleys for as long as ASP. Both are excellent companies with all the right QC controls- the end products speak for them selves.
As for trying to match the mass- its a clever answer but Im not biting. Imagine what your flywheel/clutchdisk/pressure plate must tip the scales at- I assure you its well over 9lbs- try 30lbs. I dont think ASP wanted the cycle time on thier machine to drill and chamfer the holes.
Re: Dead eye
Buell-
Buell-
Brandon, that's the story ASP gave me, could they have made it lighter without the holes, absolutely. They purposely made a thick band around the back of the pulley, their reason was for harmonics.
So are your's made by AEM? I thought you said you had them made at your local vocational school![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Revstriker, I just don't see it either but lighting can play tricks.
C230 coupe 6sp
Brandon,
Can you use your pulley without changing the alternator pulley? It seems as that is the big job that takes the most time. Does it spin the alternator too fast, or is it just to cut down on the HP loss from it spinning faster?
Originally posted by speedfrk
Brandon,
Brandon,
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
All these pictures of nicely machined metal are making me hot! Ooooooo Baby!
You can use a 56" 6 rib belt without their altenator pulley. It's available at many auto supply store including Pep Boys where I got mine for under $20. From what I've seen it underdrives about 20%+ with the Kleemann crank pulley in place. IMHO, it's a risk either way, spin it 20% faster and the alternator bearings may last less, spin it 20% slower and your battery may suffer. It's like the air filter issue, every tuner has their opinion. Use your best judgement.
Originally posted by NJPaprika230
Gee, it sure is nice of Kleemann to include a larger alternator pulley to maintain the proper rotation speed and avoid JUST this problem...
I would be agreeable to putting an alternator pulley in my car that compensated for the 20% larger crank pulley and ran the altenator at the proper speed but nobody I know makes that, if you find one, let me know!
Originally posted by 20FHK02
can't u ask ASP to make a smaller alternator pulley then pack it with the alloy pulley and sell them as a kit?
wouldn't this make problem solved and no more worries???
The reason Kleemann uses a 1" larger pulley is to get the 1 or 2 extra hp out of underdriving the alternator. Unless you do all your driving at night with the stereo blasting and fogs on you won't have a problem with the alternator charging the system as modern alternators are highly efficient at lower rpm and can deliver full output as low as 2500rpm. In other words, use the larger pulley and don't worry about it.
Borrow a factory pulley from someone that installed any C230 Coupe Kleemann pulley kit (SLK alt pulley is different) and send it to him as they'll need something to go by for pulley and hole diameter and offset. It's so small that I can't imagine it costing much.
That's why I suggested a few of you that want it ask for it as a group like I did for the group buy of the crank pulley. Decide on a size and go for it. It's actually a very simple pulley that looks like a solid hockey puck with a hole in it. It may very well be that another pulley he has already made for another car fits or is close enough so he just tweaks a parameter or two on his CNC machine (it's not like MB makes their own altenators). The width of the belt and ribs is a standard size.
