Swaybar question. C32 endlinks needed? maybe?
Old Jul 17, 2005 | 01:17 AM
Burnt Toast's Avatar
Hey, im going to be buying some used Brabus swaybars in the next few days. they are comming off a C32. According to the previous owner the holes were drilled from 10mm to 12mm to accomidate the larger bolts the C32 uses. now my question is, what is needed to make this bar fit?
do i basicly need whats need to put a c32 bar on my car? I.E. bracked, bolts, and endlinks?
or can i just slap it on and use a washer to help with the larger holes?
also.. if i do need some C32 stuff what is needed?
thanks all.
Old Jul 17, 2005 | 01:57 AM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
The '05s come with the C32 AMG sways stock. I measured them myself, I believe it was 16 or 17mm front 22 or 23mm back. I forget the exact numbers. As far as the end link goes I honestly cant remember if it was 10 or 12mm but I beleive it was 12mm. Dont quote me on that, grab a caliper and measure away!!!
-edit-
Oh just realized you are getting Brabus sways and not C32 sways! Never mind then!!!
Old Jul 17, 2005 | 02:49 AM
Originally Posted by Capt Sharkbait o7, names changed to protect the postie
-edit-
well its comming off a c32 so i would assume they are the same size as a C32.
Old Jul 17, 2005 | 08:07 AM
Hey! Didn't I say don't quote me!!! J/K...
Old Jul 17, 2005 | 02:14 PM
lol ok sorry, fixed it for you... err who ever the original poster was.
Old Jul 17, 2005 | 09:05 PM
Thanks!!!
Old Jul 19, 2005 | 01:30 AM
bump, any one know? drilled out holes from 10 to 12 = c32 fit... how to make fit on my car?
and if the stock sways are the same size as the c32 for my car are these a direct swap?
thanks
Old Jul 19, 2005 | 11:25 AM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
yes, all you need to do is drill out the holes. the will fit just fine. i did the same on my car!
Old Jul 19, 2005 | 06:44 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
same here...
C32 sways = 12mm end link holes
Old Jul 19, 2005 | 06:54 PM
you do need to drill out the holes on the car, in order for them to fit. the endlink connection on the sway will already be 12mm.
the sway connection hole on the car is 10mm, that can be drilled to 12, no prob. thats what i did to mine.
Old Jul 26, 2005 | 01:21 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Anybody know if this applies for the 2004.5 SS also? I just bought the Brabus sways from IdriveFast, but he's got a C32.
I talked to Brabus and they said it should be a direct swap with no problem. I'm pretty sure it was established that the 2004.5 refresh w/ the new wheels also included the lower suspension as well as the amg sways.
Also, on a side note, anybody know why the sways are designed to have the front thicker than the rear? People have told me that this potentially could enduce understeer and my front wheels might lift off the ground when turning (if the front swaybar is thicker).
Old Jul 26, 2005 | 03:40 PM
yes the front sways are thicker than the rear, standard and AMG setup.
Old Jul 26, 2005 | 05:23 PM
drexappeal's Avatar
Thanks, Citron.
Do you know if this enduces heavy understeer? It kinda concerned me when people had mentioned this to me.
Old Jul 26, 2005 | 08:53 PM
From what I was told, going to a too thick of a sway bar without matching it with the appropriate shocks and springs is what causes the tires to lift off the ground. This is because sway bars transfer force between the inside and outside tires to help the car corner flatter. Go too thick and the suspension cant overcome that force in high G turns and the tire lifts off.
Old Jul 27, 2005 | 12:22 PM
Thanks, Citron.
im not really sure. i havent noticed heavy understeering. i think it increased the drving characteristics of my car. the main difference i noticed was that it really improved body of the car at high speed on highway interchanges and driving curvey mountain roads.
the problem I had with the sways was refitting the auto leveling sensor for the BiX. I had to take the car to the dealer to have it attached properly.
Old Jul 27, 2005 | 05:51 PM
drexappeal's Avatar
Are you serious? So I'm assuming the auto leveling sensor had to be detached in order to install the swaybars?...Is that correct?
Man, I'm gonna have to tell the shop I'm having them installed at (Yes, I am too lazy to install myself...LOL).
Old Jul 27, 2005 | 05:56 PM
yes the autoleveling sensor is attached to the sway bar. there is a flat area on the sway where the sensor attahes. i tried and tried, but i couldnt get the sensor on properly. i had to take the car into the dealer and told them lights just started acting up. i didnt tell them i upgraded the sways, and since the are black like the originals and still have the flat area where the BiX autoleveling sensor attaches, they never said anything. they fixed it under warranty.
Old Jul 27, 2005 | 06:01 PM
drexappeal's Avatar
Wow, okay, so I'm wondering if this shop will know how to re-attach the auto-leveling sensor onto the Brabus Sways...Oh well, I'll just make them aware of it and if they can't do it, I'll take it somewhere else. Last thing I want to do is mess up my BIX.
Old Jul 27, 2005 | 06:29 PM
i cant remember which one, but when i was researching sways, there was one that didnt have the area for the sensor and this was a main reason i stuck with the AMG sways. OEM fit all around.
Old Jul 31, 2005 | 03:42 AM
drexappeal's Avatar
Semi-problem...
I hope someone can help on this one.
I went to have the Brabus swaybars installed today, but they had problems with installation. The OEM bracket did not fit over the coupling on the Brabus swaybar.
Does anybody know if Brabus has a different bracket to match up to both couplings on the swaybar or should it fit easily?
Any help would be great. I thought that having a 2004.5 w/ refresh would mean that I had the AMG suspension, but I don't think it is the AMG.
Thanks everybody.
Old Jul 31, 2005 | 04:37 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
...People have told me that this potentially could enduce understeer and my front wheels might lift off the ground when turning (if the front swaybar is thicker).
Did the same people explain how anti-sway bars work? Thicker bars do REDUCE body lean. Of course, if you push it too hard, you may lift the inner wheels, but certainly not just because of using thicker bars - with the stock bars you would not have attempted to take the car this fast through the turn because of the body lean in the first place.
Old Aug 1, 2005 | 02:26 AM
drexappeal's Avatar
Thanks everybody.
Anybody have a solution or know how to resolve my issue with the front swaybar bracket?
Old Aug 1, 2005 | 03:51 PM
drexappeal's Avatar
Still trying to find the right bracket to match the Brabus swaybars. Anybody know? I was told I needed to get the brackets from an '02, but that would be from the coupe (sedan didn't come out until 2003).
Can anybody confirm this being correct?
