Convenience Automatic Air Conditioning Upgrade Plus
btw, im a way OEM mod junkie too. i wish there was a 12 step program i could join.
MA (mod anonymous).
it would save me so much money. it's worse than a cocaine habit, ok well not that bad.
we're lucky they kinda understand the passion that we have towards the marque.
as for addictions.... i don't think that is curable.
Because i'm soon as i'm done modding the C-Coupé, (if ever !), i know my next Benz won't be rolling stock for too long !
anyways, back on topic...
Mike, i found in my stash of papers that I printed out back in 2003, a PowerPoint presentation for W203 & 463 HVAC. (507 HVAC HO 203 & 463 ACB ICC - 10-30-02).
It looks like a System Training Presentation for a course.
I'll show it to you next time we meet up.
Also, at my last Service B, the techs left a print-out of i guess was the log of diagnostic tests of all my modules, EIS, SAM, ME-SFI, etc... and
in the C-AAC section, my car gave 6 error codes all relating to communication errors of the AC bus with various components, including: charcoal filter flap adjustment motor, defroster flap actuator, footwell flap actuator, fresh air flap actuator, sun sensor, & multifunction sensor.
The DAS status is "current & stored". My SA didn't mention anything about these, but i'm figuring that's because they're not in my car to begin with.
So, i'll show you that print-out too, see if you can make some sense out of the hiroglyphic MB code.
ok, so next step, is ordering all those parts you listed:
A211 870 01 10 1 ea Sun Sensor ($43)
A211 830 04 72 1 ea Multifunction Sensor ($222)
N000000 003242 1 ea Screw
A008 545 55 26 4 ea Female MQS Pin ($1.20 ea)
A013 545 15 26 3 ea Female SLK Pin ($1.20 ea)
A035 545 73 28 5 ea Male SLK Pin ($1.40 ea)
A000 545 69 80 3 ea Seal (for MQS pins $1.20 ea)
A220 540 06 81 1 ea Plug Housing for Multifunction Sensor ($2.00)
A037 545 13 28 1 ea 2 pin SLK Male Connector ($2.00)
A220 545 54 28 1 ea 2 pin SLK Female Connector ($2.00)
# ground loop
Carlos
Saprissa@aol.com
Let me know when you are getting closer to doing this.
I have been giving doing this some consideration, and although I don't have any problems following a schematic and building the harness, the actual electrical understanding was not my strong point.
Until then, I think I will go
Thanks!
More pictures on wiring, plug in and full integration would be GREAT!
Thanks,
Jake
The author of this thread mentions having to make a harness from scratch for the Multi-function sensor only? Not for the sun sensor? So, does this mean that the plug for the sun sensor is tucked away somewhere around the area of the hood grille? I have looked and not found anything. I have an '05 C230K SS with the rubber plug in the place of the sensor and was wondering if I could go ahead and buy the sun sensor and install it right now while I gather the rest of the parts to do the digital climate control swap and the harness mod to add the multi-function sensor.
Thanks to everyone in advance!
While I was doing some "spring cleaning"...I found an old wire harness that I bought years ago with the intent to modify for this mod...
Can anyone that has added the Digital HVAC controller to a non digital OEM car please post (with images to support diagrams or pictures of cabin/console/engine bay/etc.) of how you tied the sensors into the wire harness and vehicle CAN Bus?
I was HOPING that MB would have left the plugs there, unused like in this r171 SLK; http://www.slkworld.com/general-modi...-upgrades.html
My Dealer is telling me my OEM harness a2035406633 (item 10) "should have them" as shown in image...
But I do not see them...
(No one, that I have seen or read has tried to tie in the rear passenger booster fan and potentiometer switch in the grille venting...I have most of these parts too in that box, with the wire harness...)
It wasn’t bad...just needed a “reason” to pull SAM and parts...Wiring in Distronic justified this as it all came apart in that area...
I made my own harness...as most do. Used the OEM connectors, but added a water proof one for the leg to the smog sensor. Close up by master cylinder shown here. Admittedly it’s not the best wire job from there to the smog sensor, I pulled it through once I knew it was clear of wiper/etc. (Ps.wiper has a safety on it, doesn’t like being powered up with hood (maybe) door open, etc.)
I used a pin from an old OEM climate controller harness end, and then just wired it all in. Super easy. Just do it!
Yes, the clips on the hood vent will break. Terrible engineering and material choice...I had help, soft tools, plastic wedges and patience and still some broke. It screwed back down well, just one corner is “not” as flush as I’d want it, but no one could tell...
Here you can see the waterproof connector I added/used for the smog sensor leg.
Detail/close up of waterproof connector.
I used a small ratchet tool with a torx bit to manually stew in the sensor. Arguably the most tedious part because it’s so tight. I did not pull any plastic (cowl drain, etc.) to install this...
Ran a hard wire from battery side to master cylinder and pulled my cable through.
First off, I’d like to apologize for bringing up this old thread, but I want to thank everyone who contributed such valuable information—it's been incredibly helpful.
I’m currently planning to do this conversion myself and would really appreciate a bit more detail. Specifically, I’m trying to figure out where exactly the added plug X85/9 is supposed to be connected.
Digging into the SAM diagrams, I can see that the power for the added plug (X85/9) comes from Pin 8 on Plug 19 of the Front SAM, however, I also noticed a wire that runs from the plug to the C-AAC control panel.
Any clarification would be hugely appreciated—just want to make sure I’m wiring this up properly and not missing a crucial step.
Thanks in advance for your help!
Best regards,
Best regards,
Just a quick update — I checked my Climatronic Control Unit connector (referred to as N22/7), which is a 16-pin MQS/JPT-type connector. After disassembling it, I found that Pin 11 is not populated. Does this mean I need to route a wire from the X85/9 CLIMATE/COCKPIT connector to the Climatronic control unit?
Best regards
