c230 Coupe Armrest + Cup Holder Removal
Old Jul 25, 2005 | 04:05 AM
pndxprss's Avatar
Question c230 Coupe Armrest + Cup Holder Removal
Hey Guys,
I was curious if anyone knew exactly or could explain in detail how to remove the retractable cup holder and armrest for the 2002 c230 coupe? I have been searching the forums on this subject and have so far had no luck finding the resources. I want to remove the telephone cabling meant for the hands free telephone to run some audio wires for my ipod. If anyone could direct me in the right direction or provide me with a detailed explanation with photos it would be greatly appreciated. Thanks.
Old Jul 25, 2005 | 01:46 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
How are you going to have your iPOD connect to your radio?
Old Jul 25, 2005 | 03:03 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
you can run the Aux from COMAND to the center armrest and plug it in that way! if you have COMAND. also you have to remove the center aluminum trim in order to remove the cup holder. the trim has to removed by taking out the ashtray. if i remember right to remove the ash tray you have to remove the center aluminium trim as well.
Old Jul 25, 2005 | 06:19 PM
pndxprss's Avatar
Aftermarket head unit
Hey Guys,
I will be running a mini audio jack to RCA left+right audio cable from my ipod to my aftermarket head unit's auxiliary input. Removing the ashtray and the aluminum trim is easy but from there I am at a lost on how the retractable cup holder assembly is removed. I noticed that there are two clips nearest to the shifter, which loosens it a bit but does not completely release the assembly. Once again my c230 coupe is the 2002 year model...thus before the permanent cup holder was incorporated into the cars interior. Thanks guys.
Old Jul 25, 2005 | 07:28 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
As you are sitting in your drivers seat you will see (using a light) toward the front right of the cupholder area a spot to press in and turn the cupholder clockwise and it will come right out. Make sure that you have the rubber insert removed from the bottom of the cupholder area before you try to twist the pop-up cupholder. When you are ready to put it back just reverse your procedure.
Old Jul 25, 2005 | 08:26 PM
pndxprss's Avatar
Thumbs up Freaking awsome....
Stupendous...you are the man johncl . I could not have asked for more. Please keep it coming. Anyone else have info on the removal of the armrest?
