FIX for Sedan bose subwoofer.
Bass can be greatly improved in the sedan. i have an 04 with bose and audio 30. Boy the bass wasnt there. Until that is, when I went to the dealer and told them about the ENTIRE rear shelf rattle (in reality, just the speaker grille.) they took out the rear shelf, dynamatted the metal parts in the trunk from the opposite side, put in foam insulation and filled the rear deck with expanding foam. It bumps now and can vibrate my seatback. WHAT A DIFFERENCE.
Jeff
PS. Someone sat in the back of the car while I played the THX sub intro. They asked me why my car sounded like a movie theatre.
Jeff
Not exactly. Remember that when the foam expands it weighs no more than it does in the can. If you cant stand to have a 16 oz can of foam and about 2 lbs of insulation put in your car you need serious mods... LOL
Jeff
Jeff
Dynamat jsut the lower portion on the inside of the sub shelf, where it has holes and bare metal. Best of all.... DONE FREE OF CHARGE UNDER WARRANTY!!!!... would have cost 500+ according to invoice.
Jeff
Jeff
1 Post
2002 C230 Coupe(M111)
Originally Posted by ricky.agrawal
Oh free of charge. I think I might ask BMW if they can help me out then! What is it with German cars and rattles!?
I wonder if spraying the expanding foam insulation alone will improve the bass? If so this could be a quick and easy fix for those who want more bass.
What do you think? What type of foam insulation should one buy, and any hints on how to install it?
My inclination would be to seal the subwoofer area in the package tray only. I suppose you should avoid getting the foam directly on the speaker, so I guess there would need be some method for creating a coffer dam around the speaker, and another coffer dam separating the left side speaker section from the rest of the shelf. Thoughts, please?
Probably. Just tell them that the rear hatshelf rattles like mad at random times and that you expected better from a Mercedes. Also tell them that you have tried holding down the hatshelf with someone driving and that helped.
JEff
JEff
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Jeff
Jeff
Thanks for the tips, cuz I've been dreading the possibilities (or non-possibilities) of upgrading this sound system. I wish I would've researched these boards before ordering the Bose in my car, but now I have the dilemma of how much a pain in the butt upgrading the sound system will be.
Now that you've given this info, I'm gonna ask the dealer to do this when I have my Service B!
much thanks,
drex
BOB,
Do not get the foam in the woofer enclosure. it will prevent the speaker from resonating like it should. Instead, insulate the rest of the hatshelf. Also, if possible have the dealer do this because it requires removal of the C pillar trims and rear seats (if you dont have folding ones.
Drex,
I saved you about 5gs in labor and parts to upgrade teh sound system, I am glad I could help. think about it this way: since there is yet to be a cost effective interface with the MOST or D2B fiber networks in our cars, you would have to replace the entire system... (wiring, amps, speakers, pretty much rebuild the interior to rip the wiring out.) Most of the 5gs that i was quoted for a new system was labor to remove the bose and install the new stuff... good luck with the hatshelf.
Jeff
Drex,
Jeff
BOB,
Drex,
Jeff
Drex,
Jeff
This way, at least I'll hopefully get it hooked up for free, under warranty and have the system sounding better with added bass. I just hope that I approach it in the right manner so that they do everything properly and don't just "mickey-mouse" the job.
drex
'05 C320 sports sedan
i had the same exact problem with my car. i just got back from bringing it in for the complimentary 3k mile service. i told them about the problem. it appears that they fixed it, after stuffing all this white wooly type thing under the hat deck (which they said they removed and reinstalled). the rattling/vibrating that came from the back everytime the bass was up high appears to be gone now. all under warranty. i was very pleased
Thanks in advance.
drex
'09 A4 S Line
I always noticed a slight rattle from the rear deck and the other day I realized it was the rear sunshade rattling. When I put it up, the rattle goes away. I would like a more permanent fix though, since I don't usually use the sunshade.
wassup61: Which dealer did this for you?
hey,
My invoice says "Insulate and Soundproof Rear Deck to prevent Rattle"
Hope this helps.
Jeff
Hope this helps.
Jeff
I really appreciate it.
drex
Jeff,
Thanks to your info, I think they fixed it. I haven't checked yet, but I can tell that they did something. According to the invoice, it said that they added felt lining to the hatshelf. I don't think that's enough, but if it's not is there any way you can post some pics.
That way, if they didn't do exactly what they did to your car, I'm gonna make a complaint again and have them do it right.
Originally Posted by amdeutsch
Drex
There is a thread in the audio forum where I posted a solution found on a German forum including pictures.
Okay, I was reading your thread, amdeutsch and I'm not sure if the fix they did was exactly what Jeff got done or the pic that you posted on your audio thread (btw, the german forum link didn't work).
Anyways, according to my invoice they replaced the hatshelf and they applied felt in the hatshelf. According to what you guys indicated, there was a "foam" or "silicon" that could be applied, in order to keep the foam sealed tighter.
Regardless, I'm gonna check while I'm going home. If I still hear a rattle, I'm gonna bring it back next week (after I've gotten my brake pads installed).
Jeff, if you have anymore information from your invoice that could help me, I'd really appreciate it.
Thanks.
drex
Thanks.
drex
Im looking to buy a 06 c280 and have always upgraded my systems to meet my needs. I was thinking this time to keep the vechile stock and order the premium sound. Do you guys recommend paying the extra cash to have the harmon kardon system in the vechile or to order it stock and upgrade later. I hear you talking about alot of money to upgrade. Is that from any stock system or the premium stock system? Please explain thanks JIM
