Parking mirror Problem!!!
Old Aug 20, 2005 | 09:59 AM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
My rigth side mirror turns down to see the side walk when parking but when I put 1st gear it won't go up to the memorized position!!!
I went to the dealer and he programed the mirror and it was ok until I pass the dealer gates
The dealer told me that I need to install a complete new rigth mirror!!!
My car is out of warranty for 4 months but I have a extended warranty ( called NSA in Europe) but it doesn't englobe these parts
I didn't ordered the mirror because I was thinking to order Steve the folding mirrors, but, Its there anything I can do to make the mirror work propely???
I have to suspect the dealer, don't I
Have this happened to anyone else???
Old Aug 20, 2005 | 11:02 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Yes, and in most cases it was the control module in the door and not the mirror. Been discussed on here previously. HTH
Old Jun 9, 2007 | 12:40 PM
Midnight Koop's Avatar
CL203
i know this is an old thread... but i was wondering about the tilting passenger side mirror when parallel parking...
my 2003 coupe never does it, and i couldn't find the option under the command options to activate it. one of my friends has an 2002 coupe and the option is there... is this something i'll need the dealership to do?
thanks!
Old Jun 9, 2007 | 01:25 PM
Lsrevhard's Avatar
2005 C240
have you tried programing the mirrors?
Old Jun 9, 2007 | 03:22 PM
CL203
if you're implying that i have memory seats... then no. i read on the online manual that you can program the mirrors if you have memory seats, but since i don't im not sure how to.
i called mercedes service and they said i should have the function... so who knows why it doesnt appear in my instrument cluster display as an option.
Old Jun 9, 2007 | 06:07 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
if you have that feature just put it in reverse and press the mirror button for the right hand side. if it works you have the feature if it doesn't work then you don't have the feature.
Old Jun 10, 2007 | 04:32 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Actually, I'm glad this got bumped. Anybody have the links to the older threads that discussed this? I want to see if there was anybody who got it fixed under warranty.
Anyways, mine has been acting up also, so gonna have it all on the list for service b fixes.
Old Jun 11, 2007 | 12:11 AM
CL203
i tried that... and it doesn't work... so i guess i dont have the feature.
the thing is... i called the dealership and they said that i'm supposed to have it. is it standard on the w203?
Old Jun 11, 2007 | 04:45 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i thought it is ...on the auto i believe. try pushing either one of the mirror button.
Old Jun 11, 2007 | 02:28 PM
trisonics's Avatar
2002 C230K Coupe
The parking mirror setting only works when the control button for right side mirror is depressed (the one which you press before adjusting the right side mirror). If the driver side mirror button is depressed, then the parking setting does not work when in reverse.
Old Jun 12, 2007 | 01:19 AM
hawaiian's Avatar
2003 C230K SS (6 spd)
Mine doesn't work either,......... is it only for autos or 6 spd as well?
Old Jun 12, 2007 | 07:27 AM
CL203
thats what the dealership told me, but apparently my car doesn't respond to that.
i guess i'll make an appointment.
thanks!
Old Jun 12, 2007 | 06:15 PM
trisonics's Avatar
2002 C230K Coupe
thanks!
If it has never worked for you, that is you are sure it ain't broken, then it is possible that parking mirror feature is set to 'off'. I would suggest you check the setting before going to the dealer. To change it
1. Access the menu. Use arrows to go to different menu's.
2. On the page where you see a list like Vehicle, Lighting, convenience, select 'Convenienve' and press menu buttons again
3. Use up/down arrow till you get to the mirror settings and set it to 'On'.
Hope it helps.
Old Jun 13, 2007 | 01:04 AM
mtnman82's Avatar
'16 E350, gone: '03 c230k
I have an '03 C230SS. When I go to the page with vehicle, lighting, etc., there is no 'convenience' selection. I don't believe my car has this feature ... I thought it was an option, not standard???????????
Old Jun 13, 2007 | 01:10 AM
CL203
my car does not have this feature either... i am planning to take it to the dealership first thing thursday...
