Auto folding mirrors feature set
1. Both Door control Modules
2. Front SAM module
3. EIS
4. Instrument CLuster
The first 3 are common to all C class cars with memory seats. I am not sure on the last one though. We can enable the menu in the old clusters then that should be no problem. Mirrors fold when car is armed. They unfold when car is started or disarmed and waiting a few minutes.
I notice that my friends 2003 W203 coupe had all of the programming blocks for the door controllers and the instrument cluster (although the developer mode menus were not at all the same).
It seems that the software for the front SAM (fuse box) varies greatly. There are apparently at least 3 versions (maybe 5 going by part numbers).
I am going to start looking into the FLASH upgrades for the front sam modules in SD-FLASH to see if I can update the SAM modules without having to change them. If not then we will seriously consider changing the front SAM module since we also want to code the turning lamps as well (also not coding at this time).
As for the passive cornering lights - my guess is that the reason it doesn't work is that some of the modules are set to 803 or 804 instead of 805...changing those settings to 805 should make the passive cornering lights work BUT will create some other CANBUS related malfunctions.
greetingz,
