Comand Problems.
Old Sep 6, 2005 | 03:54 PM
rubensans's Avatar
Brabus K3
Comand Problems.
Hello,
I take out comand to pass some wires.
Now, no conection to sterring wheel buttons; no reading in instrument cluster, comand button lights don't light, comand don't stop when you left the car, the auto day night mode don't work. Aux input level is extremely low.
Radio is ok; navigation is ok, tel is ok.
Any Idea? Could this be a fuse? it seems that in may be a problem with connector C2.
Thanks,
Ruben.
Old Sep 6, 2005 | 04:39 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Ruben, double check your C2 as you mentioned. I had this same problem and after I checked it was not seated properly. It is a little tricky to get in right the first time.
Old Sep 6, 2005 | 05:46 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
navigation can NOT be ok as the comand does not get a speedpulse...
Like john said - your C2 connector isn't inserted properly (or one of the CANBUS wires are loose)
greetingz,
Old Sep 7, 2005 | 11:18 AM
rubensans's Avatar
Brabus K3
Thanks to all.
Repaired: C2 was not propely connected; it look like it was but it wasen't.
Thanks again. Best Regards.
Ruben.
Old Sep 7, 2005 | 11:57 AM
JohnCL's Avatar
Good to hear. I swore mine was connected right until Steve told me to check it again. Now it is a walk in the park and if you ever have to take it out again you will be a pro!
