Smart Key not recognised for ignition.
This problem happens since one week and each time is worst.
When I put the smartkey in the car for starting it, it dosen’t recognise it (like if I haven’t put it). After put the key in and take out and another time put in several times; maybe 10 to 15 attemps, it recognise it and I hear the steering unlooking and can turn the key to start the car. Sometimes the fist time that it recognise the key, before I arrive to starting position, it stops all systems and then If I take it out and reenter it goes fine and can start the car without problem.
It only happens If I don’t use the car more than 3 hours aprox. If I stop for a petrol station all ok, or if I go to dinner, etc…. but every morning I have to do the same.
I have test it with the 2 smartkeys and the non powered key and happens the same.
Any idea of what could this be?
Best Regards,
Ruben.
I think you need I special tool to remove it and clean the other side.
Car isn't under waranty :-(
Thanks.
Ruben.
If the ignition module is bad, it will need to be replaced. Unfortunately unless you have a really good aftermarket MB repairman, it might be something only a dealer can fix.
The problem as far as I can see can be:
a) Key insertion not recognised.
b) Infrared reading wrong. (could be the red plastic glass scratched or dirty on the "DARK SIDE".
What I don't understand is why it only happens when the car is without the key for several hours.
Best Regards and thanks.
Ruben.
