W203 Technical Service Bulletins
2004 C320 Sedan
Service Bulletins
TSB Number & Issue Date TSB Title
P-27_55-50A FEB 05 A/T - Harsh Engagement/Buzzing Noises
P-83_30-74A FEB 05 A/C - Musty/Moldy Odors
P-82_10-398A JAN 05 Lighting - License Plate Bulbs Burned Out
P-54_21-133 JAN 05 Lighting - Trunk/Cargo Light Inoperative
P-54_21-121 JAN 05 Lighting - Brake/Park Lamps Flicker With Engine ON
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_21-124 DEC 04 Lighting - Headlamps/IP Lamps Flicker
P-54_21-126 DEC 04 Power Locks - Central Locking System Inoperative
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-54_21-119 OCT 04 Lighting - Tail/Brake Lamps ON Continuously
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 OCT 04 Body - Scraping Noise From Transmission Tunnel Area
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-82_10-376 SEP 04 Lighting - Xenon/Bi-Xenon Headlamps Not Functioning
P-27_60-44 SEP 04 A/T - Implausible Downshifts
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-82_20-370 SEP 04 Lighting - Dome Lamp Won't Come On
P-33_15-15 AUG 04 Steering/Suspension - Torque Strut Replacement Parts
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-68_20-29 AUG 04 Interior - Console/Armrest Lid Rubbing Noise
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_60-65B JUL 04 SRS - Warning Lamp ON/DTC's B1035/B1037/B103B/B1039
P-77_20-26 JUL 04 Body - Sliding Roof Excess Lift Control Feature
P-54_10-116 JUL 04 Electrical/Battery - Solar Charging Panel Installation
P-68_50-24 JUN 04 Interior - Sunblind Chafe Guard/Loose
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-83_40-71 APR 04 Climate Control - Heating and Cooling Set-Points
P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
P-33_10-11 APR 04 Suspension - Rumbling Noise Driving Over Rough Roads
P-82_60-303 MAR 04 Audio System - Satellite Radio Installation
S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
P-82_00-228B FEB 04 Audio System - Mutes Randomly
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-82_30-279B NOV 03 Wipers/Washers- Poor Wiper Performance
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-18_20-22 SEP 03 Engine - New Oil Filter Requirements
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-82_70-284 AUG 03 Cell Phone - Voice Activated Cell Phone Installation
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
2004 C320 Wagon
Service Bulletins
P-82_62-391 SEP 04 Audio System - Comes ON at Maximum Volume
2005 C230
Service Bulletins
P-07_61-46 MAR 05 Engine Controls - MIL ON/DTC P201A/B/Rough Running
P-27_60-43 JAN 05 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-82_85-423 JAN 05 Instruments- DV COMAND(R) Display Misaligned
P-68_20-33A NOV 04 Interior - Center Armrest Lid Falls Off
P-82_70-377A OCT 04 Cell Phone - Poor Signal Strength
P-80_57-30 OCT 04 Electronics - CGM Deletion/Electronic Ignition Switch
P-05_20-13 OCT 04 Engine - Rattling Noise on Start-Up
S-07_08-43A OCT 04 Engine Controls - CVN Recoding After Module Replacement
P-91_60-76 AUG 04 SRS - Warning Lamp Illuminated
2005 C230 CL
Service Bulletins
P-77_20-27A MAR 05 Body - Panorama Sliding Roof Noises
2005 C240 4Matic Sedan
Service Bulletins
TSB Number & Issue Date TSB TitleP-83_30-74A FEB 05 A/C - Musty/Moldy Odors
2005 C240 4Matic Wagon
Service Bulletins
#32
2005 C240 Sedan
Service Bulletins
#33
2005 C240 Wagon
Service Bulletins
#34
W203 slightly modified
Posting a list for the sake of it doesnt mean that the items included are relevant to all cars in all situations. The work order list for each given car only comes up with the VIN.
#35
2005 C320 4Matic Sedan
Service Bulletins
#36
#37
2005 C320 4Matic Wagon
Service Bulletins
#38
2005 C320 CL
Service Bulletins
#39
Originally Posted by ricky.agrawal
Precisely, it's just a place to start for many folks and I hope it will avoid many posts regarding stuff like 'what needs to be done to my car' and stuff like that.
It like giving a disease book to a hypochondriac.
#40
2005 C320 Sedan
Service Bulletins
#41
That may happen once all the threads about "WTF does it mean" die down.
NoSleep (07-22-2016)
#42
2005 C320 Wagon
Service Bulletins
#43
Haha, let the dealer take care of them ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
The dealer will gladly waste more money than is needed to make sure that nothing was found and no fault was present. You could provide the information that is requested and not just something which may or may not apply.
#44
#45
Not if it's under warranty.
#46
There is no such thing as a free lunch. Asking for work to be done when nothing is wrong is not free at all dealerships in all locations.
The guys at our BMW dealer are a lot more receptive. They probably deal with a younger crowd all the time so that might be why.
#50
Unless you have an Alldata account, no.
Furthermore, with a user token from MBUSA you may have the right to search and read these documents at your own leisure.
http://www.startekinfo.com/StarTek/subscribe.jsp
As I said before .... providing excessive amounts of information doesnt help if you get the facts wrong.
