W203 Technical Service Bulletins
Rating: Thread Rating: 8 votes, 5.00 average.
Old 09-24-2010, 05:27 PM
  #76
juan wood's Avatar
2001 c320 sedan
I was able to get the number and date of the TSB where can I go for an actual copy of the document
Old 10-08-2011, 10:53 PM
  #77
04mbc230's Avatar
2006 C230 Sedan
Any services / recalls for 06 & 07 models to complete the w203 section?
Old 01-17-2012, 07:00 PM
  #78
lomita's Avatar
C63AMG
Thumbs down DTC B1037 R12/21
Solid illumination of the SRS on 2003 C32 AMG instrument panel. StarDiagnostic code listed above, SRS right front door, airbag. Apparently,
there is an open in the wire so WIS suggests repair kit for the fix. Only the dealership can fix and they won't sell the part A0005407905 over the counter. It's one of them alien fixes, you know, rocket science BS. I think the squib connector has a fuse in it, the repair being to cut off the existing connector and solder a new one in place. Too bad we can't get the part! This will be my last Mercedes...............hat's off you to Corp. Am. MB for the lack of support.
http://www.justanswer.com/mercedes/1...2003-c240.html
Last edited by lomita; 01-17-2012 at 07:09 PM. Reason: http://www.justanswer.com/mercedes/13d1d-replaced-left-front-door-2003-c240.html
Old 09-10-2012, 11:48 AM
  #79
ecaman77's Avatar
2015 ML 250
Guys, do we have a list for 2007 models.
I just went to the dealer for an oil change this past saturday, and they had a new recall for the cables of the cam sensors.
Can we get an updated one for 2007?
Old 12-12-2012, 05:09 PM
  #80
aawami's Avatar
c180 model 1998
Hello all, when i use the remote control to lock or unlock my 1993 mercedes c180 the hazard flashing on right side only. How can I fix this problem?
Appreciated your Cooperation.
Old 11-27-2014, 10:21 PM
  #81
annee's Avatar
mercedes 2001 c240
how to reset after service w203
Can someone please show or tell me how to reset after service
Old 12-09-2014, 09:29 AM
  #82
C..Mr Amg's Avatar
06 C230 sport sedan
You can use youtube.com....I reset mines using the site.
Old 06-11-2016, 12:30 PM
  #83
skodje1620's Avatar
C 240
Corrupted EIS '02 C240
My battery discharged and was removed for charging. Prior there were codes for SRS, ESP, ABS and misc rear bulb faults, When battery was hooked up, computer faults went nuts with codes, locks, lights, windows, horn, cooling fan. Was told that,for starters, the ignition switch and key had to be replaced. Is it possible to re-program a used switch or must I go through the dealer?
Old 11-05-2016, 11:08 PM
  #84
VVF
VVF's Avatar
2005 C230K(sold), Mk7 Jetta
Guys, check for takata airbag recalls on W203. Campaign number 2016090001.
Can check for open recalls here: https://www.mbusa.com/mercedes/recall
Old 10-29-2018, 11:59 PM
  #85
Iwuala Chibueze's Avatar
C280 4MATIC W203
This link does open
Originally Posted by bnzct
Check this link for the latest MB TSB's, campaigns, Recalls...
http://alldata.com/tsb/Mercedes-Benz/index-post.html
This link doesn’t open any content, when the web is about to load, it shows error.
Old 01-29-2020, 12:47 PM
  #86
B-5
B-5's Avatar
C230k, W210
Has anyone received any information regarding this recall?
https://www.nbcnews.com/business/con...could-n1111071
Old 08-27-2020, 09:46 AM
  #87
StevenVN's Avatar
W203 C200K
Dear Team,
The W203 c200k recall program will it apply at VN country ?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: W203 Technical Service Bulletins
