Door Seal
Old Jul 16, 2002 | 08:33 PM
DCX Engineer's Avatar
Door Seal
My drivers side door seal is coming loose at the bottom of the door. Young mentioned in another thread he was going in for warranty work for a door seal. Is this a known problem? My search results were not too helpful. I was planning on having mine replaced by the dealer at my "A" service in another 1300 miles.
Old Jul 16, 2002 | 08:48 PM
young's Avatar
GLB 250 4matic
here's a pic of mine. i just realized, one day, that i could see yellow at the door. i wondered if that was supposed to be like that. so when i went to the dealer, i just asked them to look at it. he said that the adhesive was gone and that they would replace the seal.
Old Jul 16, 2002 | 09:00 PM
Mine looks identical. Thanks
Old Jul 16, 2002 | 09:10 PM
MB-BOB's Avatar
Admin Alumni
See Garage
I had a similar problem with one of my doors. They fixed it easily and the seal hasn't fallen again.
Old Jul 17, 2002 | 09:31 AM
MBSang's Avatar
14 ML350 4MATIC
I have a same problem on my passenger side. same location.
Damn, I should call them up.
Old Jul 17, 2002 | 12:49 PM
viper's Avatar
All the coupes have this little problem. It is a one piece seal that is slit. The yellow you see behind is a mounting flange. If you look at the sides you will see a pink mounting flange. Sure they can replace it but once the rubber starts sagging a bit you will see the yellow again. I don't think this is a defect it is just inherent in the design of the seal. And it does not degrade the seals ability to function like it should.
