AMG sways for Coupe
AMG sways for Coupe
Going to install my AMG sways on my coupe tomorrow... does anyone have any suggestions or advise. I have never tried it before? kinda assume its a bolt off/bolt on thing?
2003 C230K Coupe Orion Blue
I wrote exactly the thread you need at www.mbklasse.com. Won't post the link here, but become a member and run a search on the DIY section.
btw the sways imo give you the most bang for your buck in terms of upgrades. Enjoy the ride
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
The only PITA is getting the rear off. It makes it easier if you can just cut the muffler pipe off but since that's not feasible, remove one of the wheels so you can twist it around and get it off.
Would be very difficult to do without getting underneath. Because the sway bar is a different diameter than stock, the end links for the front AMG bar are also bigger. I remember a discussion on MBKlasse where some people said you didn't need to fit the bigger end links. I think that's wrong and did, but the stock hole for the upper mounting bolt needs to be drilled out larger if you bought the end links as well as the bar.
It's a great upgrade.
