COMMAND install question
Old Oct 16, 2005 | 11:24 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Well,
I installed the US-Spec DVD COMMAND in my 2005 C230. No problems there. I went to my Service Advisor at MB to have the car version coded. He said no prob.. (and no charge ). However, after I left there, I was messing around with the command and I cannot get the navigation info on my multi-function display between the tach and speedometer. What do I have to tell the advisor specifically to get the display to come up..I thought the version coding would bring it up.
I also have the OEM SAT radio and OEM phone installed in the fiber optic loop.
Thanx
Old Oct 16, 2005 | 11:42 AM
underwhirled's Avatar
05 C230 Sports Sedan, Previously owned an 02 C230 Sports Coupe
I can't really answer your question, but I was wondering where you got your command as I am also looking to do this mod. I can get the Euro Command, but I want the US spec command.
If I can locate one at a reasonable price, I too may need to know the answer to your question.
Old Oct 16, 2005 | 12:47 PM
SUNILP's Avatar
2015 E250D
to get the nav info up, you need to tell your service advisor to
USE SDS system
go into IC module
version coding
then optional equipment
then NAVIGATION=PRESENT
Old Oct 16, 2005 | 06:47 PM
benzmodz's Avatar
W203 slightly modified
Originally Posted by capt_paul
Well,
Thanx
The version coding only works when you are using the navigation. Otherwise it says "NAVI ACTIVE".
Just keep pressing the airbag buttons.
Old Oct 16, 2005 | 08:14 PM
SUNILP's Avatar
2015 E250D
On 2005 Cars, it should actually give a HEADING reading on the cluster.
