Heated seats
Old Nov 5, 2005 | 05:28 AM
valdes's Avatar
05 C55, 01 C240, 00 Discovery
Heated seats
I want to install heated seats i was looking all night around the forum and couldnt find any succesfull job or part numbers, etc.
If you guys could help me that would be great
Old Nov 5, 2005 | 05:52 AM
valdes's Avatar
this is for the c240 and i was reading that some 209 came with the heating element is this true for the 240 as well and how do i figure it out and if it does come with it what do i need
Old Nov 5, 2005 | 06:18 AM
benzmodz's Avatar
W203 slightly modified
Sunman did a major makeover of his seats using W209 and W211 technology and I did heated front seat in my car.
It has been done many times .....
Whenever you buy replacement leathers for your car (even if you have fabric you buy leather) the seats always come with heating in the W209 and W203.
In the W202 / W463 / W168 the heater is a pad not part of the leather.
You need to check under your seat for starters.
Shopping list
* switch row with seat heater icons
* wiring harness
* replacement seat leathers (headrest is not heated)
Old Nov 5, 2005 | 06:21 AM
valdes's Avatar
my c240 has the leather inserts do those come with the heating element and how much was the toal mod? aprox?
Old Nov 5, 2005 | 06:32 AM
Bing's Avatar
C320 Sport Sedan 4MATIC, Cayenne S, Bayliner Capri V8, Subaru STi
are you a cold person?
i use the heated seats 3-5 minutes tops!
once it gets hot i turn it off, it's annoying, plus i don't want hard boiled eggs
Old Nov 5, 2005 | 08:01 AM
valdes's Avatar
I dont heve heated seats
Old Nov 6, 2005 | 01:39 AM
Zillarpillow23's Avatar
I would love to do this to my ride. I bought used and it didn't have that option. How would one go about installing this feature? Is it easier to have it done at the dealership and how much would they charge? I've always wondered about having options installed on a used car weeks or months after the purchase. I had heated seats in my GTI and they were most comfortable especially for people with bad backs. I miss that feeling because it was most therapeutic, seriously. How do I get started?
:v
Old Nov 6, 2005 | 01:50 AM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
my next big mod is going to be the W209 Heated/Vented/Orthopaedic seats.
Old Nov 6, 2005 | 06:54 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
NO, but when you buy replacement leather, it will come with the heated elements.
greetingz,
Old Nov 6, 2005 | 06:59 AM
benzmodz's Avatar
That's no understatement ... big is the word.
Are you going Designo Duo Tone ?
Old Nov 6, 2005 | 01:04 PM
i would love to but that mod is going to cost about $4000 for the front seats alone. so i dont think ill be doing the back seats. though ive been thinking about it because if i did i would install rear seat heating elements. can i get the Designo duo tone with the vented seat leather?
Old Nov 6, 2005 | 01:54 PM
Bing's Avatar
Exclamation Hot!
and this {{{{{{{{{{{vibrates}}}}}}}}}}}
12v Car & Home Luxury 4-Motor Back Massage System with Warm Heat
One-piece back and seat cushion designed to provide you with sitting comfort while riding in any vehicle or relaxing at home. Features Heat & Massage
Features:
Ergonomically designed hand control puts massage, pulse, and heat at your fingertips.
Four massaging motors relax your upper back muscles, lower back muscles, and thighs independently or together.
High, medium, and low level massage and pulse options.
Heat option soothes tense muscles and warms your body.
Heat coil located in the lumbar and seat area.
Car adapter plugs into 12volt vehicle cigarette lighters.
Three automatic shut-off safety devices:
30-minute auto-shut-off device: After thirty minutes, the Driver's Seat automatically shuts itself off.
Temperature-sensitive safety device: The heat function automatically shuts off when the temperature reaches its high and automatically turns on again once the temperature lowers.
Weight-sensitive safety device: The heat function automatically shuts off when your bodyweight is removed from the Driver's Seat.
High-density foam in the neck area provides additional cervical support.
High-density foam in the saddle area reduces pressure on your sitting bones.
Lumbar pad provides comfort and support for your lower back, reducing spinal strain.
CA 117 fire retardant.
Ribbed cushioning to provide air ventilation.
Pouch with hook and loop closure conveniently holds the hand control when not in use.
Six additional elastic straps and four plastic hooks hold cushion securely in place.
Folds for convenient storage.
Sporty design complements the interiors of today's high-performance vehicles.
Includes a car adapter that plugs into 12 volt vehicle cigarette lighters.
Includes AC adapter for usage in the home or office.
Adapter meets regulatory requirements.
Limited warranty against manufacturer's defects.
Black only.
Approximate Size: 22"H x 1/2"D x 43"H
Availability: Usually ships the next business day.
12v Car & Home Luxury 4-Motor Back Massage System with Warm Heat Obus-92Regular price: $99.95
Sale price: $74.95 (You save: 25%)
More Here
Old Nov 6, 2005 | 01:57 PM
i dont think it will look right.
Old Nov 7, 2005 | 09:40 AM
mctwin2kman's Avatar
And I use mine everyday! I rarely turn on my actual Heat and use the Heated Seats instead. Just bought I kit to do my drivers seat on my W201 as well. They do not stay hot as hell when set to setting 1 so normally I use the two setting and let it switch to 1 and never use my heat. Which is why I got them for the W201. Some use them a lot some use them only when really cold.
Old Nov 7, 2005 | 11:29 AM
SUNILP's Avatar
2015 E250D
i use my heated seats with vented feature. It blows warm air then.
Old Nov 7, 2005 | 05:07 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
I use it everytime I am in the car. I find it very comfortable and it helps my lower back
