Brakes
Old Nov 8, 2005 | 01:57 AM
m-benzw203's Avatar
01' C320
Brake lining pad light
hey how much is it for new brakes on a benz c320 on average
Old Nov 10, 2005 | 03:38 PM
m-benzw203's Avatar
01' C320
Brakes
how much is it for front brakes nomally b/c i am getting some for 300 with labor.
Old Nov 10, 2005 | 03:43 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Need to clarify a few things first before anybody can respond
1) What model do you have (240, 320, 230 K, 230, 280, 350)?
2) What year?
3) Where do you live? (Price can vary in different areas)
4) Brake pads or pads and rotors? And what kind of pads?
I suggest you put the make, model and year of your vehicle in either your profile or signature. That way, nobody will ever have to ask, if you ever start another thread again.
Now, with that being said, please respond with info so that we can help further.
Old Nov 10, 2005 | 03:44 PM
Sauceboy01's Avatar
Blimp
2) What year?
There you have it.
Old Nov 10, 2005 | 06:04 PM
drexappeal's Avatar
So, I guess the "no response" means either you found the information via "search" or you just don't need help?
Old Nov 10, 2005 | 11:08 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
maybe another "little Billy"
Old Nov 11, 2005 | 01:53 AM
m-benzw203's Avatar
01' C320
sorry about that guy's i have a 2001 c320 what i need is pads and rotors
Old Nov 11, 2005 | 05:22 AM
AMG_55's Avatar
mymbonline
front or both?
is that price for oem parts?
Old Nov 11, 2005 | 05:38 AM
drexappeal's Avatar
If you're getting a quote of $300 for both pads and rotors (front only), the price is pretty decent, however, see how much more it would be for them to upgrade your fronts to the 4 piston sport calipers, rotors and pads from the '04.5 model. Never hurts to ask.
Old Nov 11, 2005 | 06:53 AM
tmak26b's Avatar
I thought brake job on the C230 was relatively easy. The only thing i dont understand is that the stock rotors was warpped by 12K. The new ones I put on are starting to warp after 1500 miles. Is the stock mbz rotors that crappy?
Old Nov 11, 2005 | 02:38 PM
m-benzw203's Avatar
01' C320
ya i ownly need front pads and rotors for my 01 C320 they are charging me 300 final cost. i know this guy through my dealer and he is giving me a deal i just wanted to know if that was a good price or to check other place that u guy's might know. :>
Old Nov 11, 2005 | 02:51 PM
drexappeal's Avatar
Are you tracking your car? Why the heck are your rotors warping so fast? I can understand rotors fading (i.e. surface become rough, due to friction with pads), but warped rotors is a totally different story.
Old Nov 11, 2005 | 02:53 PM
drexappeal's Avatar
I would ask him how much extra it would be to upgrade to the 4 piston calipers and cross-drilled bigger rotors that are on the 2004.5 sport models and/or AMG C32's! If he's giving you this price on regular OEM replacement, might as well see if you can upgrade for a reasonable price also.
Old Nov 11, 2005 | 02:57 PM
respdoc's Avatar
CLS
It is..and if this guy is trying to save money that's the way to go.
M-Benz,
I'm willing to bet there's a DIY sticky somewhere around here also. If your incompetent in that field then you will have to pay someone for there time that knows how to install them. Every shop in every town charges a different price on labor so starting a new thread is pointless on this topic.
Old Nov 11, 2005 | 03:11 PM
Sauceboy01's Avatar
Blimp
Try to stay off the breaks after a heated drive. When you come to a redlight so on and so forth, try to either put in park (Auto), or let it idle in manual on 6spd (wont work on hills etc.)
This is what i do, and i'm @ 20k miles with my breaks still fresh. (and i push my car everyday)
Old Nov 12, 2005 | 01:22 AM
m-benzw203's Avatar
01' C320
someone mentioned about getting 2004-05 brakes and rotors for my c320 01'. how does that work and will that give me better braking and last me longer.
Old Nov 12, 2005 | 08:30 AM
drexappeal's Avatar
For my model ('04.5 - that's 2004 1/2 NOT 2004-2005) and for the C32's, the front brakes have 4 piston calipers (bigger calipers) and the 2004.5-present sport models have cross-drilled rotors that are bigger than the normal rotors.
Yes, this will give you better stopping power. As for lasting longer, it depends on how you drive and how you brake. If you're out there beating your car up and stopping hard/late, then your brakes are not gonna last as long as you want them to.
Regardless, from what I've heard, the OEM rotors that the C Class' had before the 2004.5 re-fresh were not very good. That being said, that's why I mentioned you should check if they can get you the re-fresh brakes from the 2004.5 (my model year). The 2005-present models have 2 piston calipers. My model has the 4 piston calipers, which are the same calipers as the C32 AMG, except it says Mercedes Benz on the calipers instead of AMG. They only did this for the 2004.5 "re-fresh" models. I can try to get the part number for you when I have a free chance. Mercedes normally doesn't give out part numbers, but I'll do my best.
drex
Old Nov 12, 2005 | 10:27 AM
tmak26b's Avatar
Nope, not this car. Matter of fact, I only drove this car for about 100 miles since I changed the brakes. My gf had the car most of the time, I bed them in properly. I just think the rotors are so crappy that they wrapped that quickly, no idea why. Maybe that's why they are only 60 a piece, $%^&*. I will also try balancing the wheels and aligning the car, but i doubt that will cause that much vibration. I will also check for bend wheels
Old Nov 13, 2005 | 01:21 PM
stephen4785's Avatar
2001 C320
I paid around 110$ for Rotex pads and 7$ each for new sensors.I installed them myself.If you want to install them yourself let me know cause Iv got complete pic's of how to do it and what tools you need.
Old Nov 14, 2005 | 12:19 AM
m-benzw203's Avatar
01' C320
thanks for the offer but i got them done, but way don't u send the pic's so if i need do it in the future i can do it thanks
Old Nov 14, 2005 | 12:38 AM
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
hey Steven, I'm interested! can you please post pics or e-mail them to me? nlpamg@gmail.com
Thanks!
Old Nov 14, 2005 | 03:33 AM
AMG_55's Avatar
mymbonline
change ur own brakes and save 100-120 $. i do
by the way, the c230 4 piston brakes and the c32 brakes arent the same
Old Feb 14, 2006 | 07:58 PM
n1ml's Avatar
2002 E320
Do you still have the pictures? I plan to do a 2003 C320 this weekend. Thanks
Old Feb 14, 2006 | 08:14 PM
drexappeal's Avatar
Really? I wonder why the parts department told me that the part numbers were the same.
Old Feb 15, 2006 | 01:42 PM
terry-6speed's Avatar
2006 W203, 2001 Porsche Boxster
Warpped Rotors - Brakes 101?
General censes from the Pro's is that rotors do not warp. What will happen is if you clamp the pad to the rotor when both are extremely hot you will change the structure of the steel in that spot and it will wear unevenly from that point foreword. Sometimes referred to as a glazed rotor. Eventually this causes it to be out of balance or appear to be warpped. There are differences in the in the quality of rotors, so some will be more susceptible to this then others.
Prevention: Racers learn early on never to apply their emergency brakes or stay on the break pedal after a race until the rotors and pads have cooled down - - - good advice for any spirited or mountain road driving. Another piece of good advice for keeping your brakes in top condition is to break them in properly (also called bedding them in). There are many articles on the web on how to do this and it is well worth the effort any time you either buy a new car or change either the pads or rotors. Hope this is helpful!
