19" with 5mm spacers to clear BBK
i was required to use 5mm spacers for the front on 19x8.5 with an ET+32. based on a lot of STFF, this offset should clear the big brake calipers without spacers. here are my questions ...
1) do you think MB changed the BBK on 2006 W203 Sport Sedan?
2) should i be concerned eventhough it's hubcentric?
TIA
TIA
Might need the spacers to clear your shocks. Brakes for 05 and 06 are the same. You're fine since your spacers are hub centric, which eliminates any vibration to the steering wheels. Congrats on your new wheels.
What kind of spacers did you get that work on the front? For some reason the spacers I ordered from bekkers won't fit over the longer hub on the front, so I'm using them on the rear.
Originally Posted by ekimpay
thanks. japanese wheels on a euro car in america ...
I have 3mm spacers/centering rings all around, and I think that I'm fine.
just found your post on it. are the 3mm generic from tirerack or are they H&R/Eibach/Lorinser/Brabus? thanks.
Hm... strange. Didn't think the caliper would ever hit the wheel when it's hot. Again, I could be wrong. Well all in all, if the spacers are hubcentric and you got longer bolts then you're all good. I wouldn't worry about it if I were you.
Let me know about the exhaust Mike. Thanks.
nlpamg -- thanks.
not sure what you meant. but, here's picture of the caliper clearance with 5mm spacers and +32 offset wheels (so it says).
Originally Posted by Sauceboy01
both the pics!
it's actually on the calipers. the installer is worried that if the caliper heats up, it will touch the rim.
i tryed to mount a set of brand new and they hit the caliper...i got a great deal on them.. 19x8.5 front and 19x9.5 in the rear for $676 for all four... im a dealer buy the way heheheh... i dont know what to do?? and what tire sizes are u guys running on the front with spacers... and does it stick out alot???
I was in NC for the holidays and saw a guy in a 05 w203 with some 18" bling wheels, I swear he must have had 25mm spacers on the front wheel, it was sticking out past the fender, and the rear was sunken in! lol
As long as your car doesnt look like THAT, your A-OK with me! LOL
Looks like WORK VS-XX wheels?
Originally Posted by sdsilverm3
Eh? If the caliper is able to heat up that much and expand I would think you have other issues. :p
Originally Posted by RedKen06C230
... what tire sizes are u guys running on the front with spacers... and does it stick out alot???
hmmmm, looks like the size of the spacer
the pic is with the 5mm spacer, and i think the clearance is about 5mm. so whithout the spacer, the caliper may be rubbing the wheels.
the heat rotor and pads generate is not high enough to make the caliper expand and touch the rims.
I haven't see the pic of your car with those wheels? what brand are they anywayz?
Originally Posted by FrankW
you're good with it.
thanks. i'll probably try it without the spacers when my pads wear out a little bit. it's the Lexion 105. i've posted some pics in the picture thread. also a link in my sig.
The wheels looks cool, but too bad it doesn't fit correctly without spacer. I think the problem you are having with the BBK clearance is because the offset of the wheel is wrong. I have talked to a few different rim shop before about finding wheels that would fit my w203 with BBK. But according to the guys at Factor One Garage, you can't just base on the offset of the wheels to determine the clearance for the BBK. From what they told me, there is actually 2 different mesurement or so call offset on the wheels. There is an offset for the face(aka: back spacing) of the wheel, and an offset of the barrel of the wheel. My guess is, the wheel you have has incorrect offset(aka back spacing) for your car.
brake pads doesn't affect how far the caliper sits on the axle.
