Busted lugg nut.... ???
Old 01-13-2006, 07:10 PM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
i busted a log nut when i was putting on my factory tires on the car for winter.... i am wondering if...
1. is this something that i should get fixed right away?
2. was told that the rotor will have to be replaced...
3. anyone think i could get this covered under warranty?
-Thanks
Carino
charles@carino.com
Old 01-13-2006, 07:53 PM
w203's Avatar
if the thread on the rotor is not stripped, you can just replace the lug nuts. Most cases, the lug nut is the one that stripped, that's way the lug nut can't go into the rotor. I'll get new lug nut first to see if it works before changing the rotor.
I hope this help. Good Luck
Old 01-14-2006, 02:59 AM
ML55CLA45's Avatar
owe... the lug nut broke in half.... half is the thing is in the rotter... and the other half is sitting on my garage floor...
thanks
-carino
Old 01-14-2006, 05:09 AM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
you can use an eazy out. you can get it at any hardware store. what it is, its a drill bit that turns the other way. you have to drill the stud a bit just do it slow and easy, you dont have to drill it all the way. after try using the easy out until it grabs. good luck
Old 01-14-2006, 01:40 PM
Cappa26's Avatar
A box on 4 wheels
If you broke this yourself, no the dealers will not cover it. Get the lugnut replaced for 5$ a piece at the dealers. Take it out yourself first or they'll charge you a service fee which is way to high.
Quick Reply: Busted lugg nut.... ???
