W203 TV Tuner antenna & COMAND GPS antenna part numbers
1 Post
2005 Mercedes C230 Sport Sedan (W203)
There are two elongaded holes, one on each side of the cluster. Put your coat hanger down there and when it hits the end, push in an additional 1/4 inch, while simultaneously pulling that side of the cluster forward. Do it one side at a time.
http://www.youtube.com/watch?v=pDADClzM160
1 Post
Antenna: 203 820 09 75
Adapter Cable: 6 7 82 3533
I believe this antenna can be used for both the pre and post facelift comand, though the adapter cable is needed if you're using it with the post facelift (2005+). I personally tested these part numbers to be working with my 2005+ comand.
Someone else should verify if they've used this part number on a pre-facelift model.
2003 SL55, 2010 C63
#34
Aren't the TV adapters going to be obsolete in Jan. 09 in the US ?
(digital broadcast)
(digital broadcast)
#35
2006 C230 Sports Sedan with Comand MCS II
Do these part numbers work with my 2006 C230 SS? Do I need the adapter as well? Thanks.
