W203 TV Tuner antenna & COMAND GPS antenna part numbers
![Arrow](https://mbworld.org/forums/images/icons/icon2.gif)
Can anyone help? w203 genuine tv tuner antenna & gps antenna part numbers required. thank you in advance. Also what is the antenna for in the new w203 models sticking out of the rear windscreen?
Originally Posted by perdikoula888
thank you for the part number. how about the second roof gps command antenna and also the TV tuner antenna?
W203 slightly modified
All different.
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
sorry for the incomplete information. I am looking for the sedan part numbers
The phone and GPS antenna are not connected. They are individual items.
For unlocking codes 762 and 763 = A 203 820 69 89
For unlocking codes 761 = A 203 820 72 89
If you buy the wrong unlock code antenna your car will no longer respond to the radio function of the key fob. I understand that 761 is valid for Japan. It appears that 763 is unlock or panic.
In other words do i need to order part 2038206989 in order to take full advantage of comand/tv or I can still leave the original I have into my car?? Also is there and additional antenna part that I have to buy for the tv tuner?
Originally Posted by dal dahele
i have a disk that contains the part no's i can post it to you if your interested
TV, unlocking and radio are included in the replacement part. Maybe you should let someone else handle this.
Originally Posted by johncl
I would like the part number for the '02 and '03 c-coupe rear window exterior antenna if possible.
Originally Posted by benzmodz
You mean to say you want the base for the phone antenna ?
The whole antenna assembly that is at the top of the glass on the hatch. Some coupes had it and other didn't, and another member had requested the part number but nobody knew what it was. I am just trying to get it for him.
You asked for the external antenna and that is only the phone in a W203.
Is it internal or external. Since the phone is the only external component.
That would be it then, the external phone antenna part number. Thanks...
Then there is also the underside base antenna you cant see. Since it isnt simple you need to find out what you are looking for and its application.
There are several types. One for GSM and one for USA.
C63
need a part number quick - GPS COMAND Antenna W203 2005+
Guys do any of you know the part # for the hide away gps antenna c class year 2005 and up? Its the one you can use for a command unit.
1 Post
2005 Mercedes C230 Sport Sedan (W203)
Antenna: 203 820 09 75
Adapter Cable: 6 7 82 3533
I believe this antenna can be used for both the pre and post facelift comand, though the adapter cable is needed if you're using it with the post facelift (2005+). I personally tested these part numbers to be working with my 2005+ comand.
1 Post
Put it behind the instrument cluster on top of the yellow foam. You can route the cable through the opening on the right which leads down to the area where the comand mounts.
02 cl203
check out the diy cluster removal
