"mickey-mouse" cell phone holder??
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
I know that most members prefer, slick, professional, quasi-OEM mods, but can anyone recommend a "mickey-mouse" (i.e. easy to rig up, cheap, no damage to car) method of holding ones Bluetooth phone in the car, such that it is visible, not in the way, but in proximity to the cigarette lighter? maybe a vent-mount or other?
How 'bout this one?
The key element of my solution is a Handsfree (brand) "Sticky Pad" gel sheet, available at computer stores (even saw them at Wal-Mart auto section recently). It self-adheres to an "L" shaped plastic bracket, fashioned with a bench grinder from one of those plastic file folder stands I found thrown in the office trash bin. Velcro the long side of the "L" bracket to the inside of the cubbie hole. Simple, elegent, and out of the way, removable, etc...
Now, for you snobs that don't find this solution "Gucci" enough, keep in mind that anyone who sees my little Rube Goldberg setup is very impressed with how close the item hugs the dash, and how the phone never falls off. Just remove the pad and wash it twice a year, and it regains its stickiness -- the phone defies gravity for months. I have taught several friends how to make their own.
BTW, I've tried sticking the gel to the Tan dash between the cubbie hole and the glove box, but it has a slight curve in it when placed there, so the phone will fall off. To hang the phone vertically (or nearly so) the pad surface has to be flat and the back side of the phone needs a flat plane, too.
so that sticky pad holds the phone, even in that near-vertical position? and it "sticks" the plastic piece you fashioned as well? so the only "fastening" you had to do was the velcro itself: stick the vel- to the side of the cubby; stick the -cro to the custom plastic piece, and that's it?
You've got it, exactly.
The Handsfree Sticky Pad is sticky on both sides, but sticks more securely to the bracket (so it never comes free when you remove the phone). Nifty, huh?
Handsfree makes two kinds of sticky pad, an original thin sheet, and this thicker, gel-composition type. You want the gel kind. I place one of the thinner sheets on top of the dash and place my cell-phone earpeice/mic on it... occassionally a pair of sunglasses too. Neither one moves while driving.
Finally, these pads leave no residue on the car's dash pieces when you remove them.
Hey MB-Bob, I bought a sticky-pad ($5.99, Staples), but haven't yet scrounged a piece of plastic for the "mount".
I have to ask: have you considered making these and selling them, either at a large mark-up or for a nominal fee (either way, it wouldn't be much)?
Assuming you won't become a "manufacturer", I'm searching for just the right piece of plastic. In the meantime, I put the sticky pad in a few different places, as an experiment, and I wasn't able to duplicate the holding power you describe in the near-vertical orientation your photo seems to show. Yours must "recline back" ever so slightly....
2004.5 C 230
You could try this from Harrington www.herringtoncatalog.com/r104.html
I'm not in the manufacturing business for this, but here are a couple suggestions for plastic... Hit the office supply store for Plastic bookends, plastic file folder holders, harddware store for angle brackets for shelving, draperies, etc. You could also ask about some angled aluminum (scrap) from a local metal fabricator.
Yes the mount reclines about 5 degrees. About the same angle that the dash reclines. Not much though.
Although I don't think MB-BOB can get rich off of his little creations, they are impressive. He also has a dead pedal and a custom flat hood ornament, and I'm sure many other custom gadgets!
OK, here's the mount. It's just an L-shaped bracket made from a black "smoked" plastic, manila file folder organizer. Imagine the upper right picture... the long vertical edge with the velcro attached is one of 6-7 upright dividers, while the shorter base at bottom is the notch between the dividers. Also looks a bit like a book-end, too, doesn't it?
The parts that are hidden within the cubby hole and behind Sticky Pad can be roughly finished (as you can see).
Also, you can see the "tilt" angle on the long tang is not much at all. Just grind the tang leaning to one side. Take a piece of cardboard, fold it, and trim with scissors until you get the shape desired, then transfer to the plastic. You WILL need a belt sander mounted on a bench to shape it.
2013 c300 4matic, 2002 c240
i found this site. anyone try these?
http://www.arkon.com/phonemount.php
y'know, when I was a kid, I was a champion mouser. give me a roll of duct tape and some paper clips and...well, I digress. here's what I did. I took one of those monster paper clips one would use for a 200 page document and clipped it to the console. then I removed the "handles" from the clip, attached my cellphone using the belt clip, and, voila, hands-free cradle. total cost, zero (the clip was on a 200 page document I had to review---I replaced it with a rubber band)
![](http://img.photobucket.com/albums/v115/eddieo45/IMG_0493.jpg)
![](http://img.photobucket.com/albums/v115/eddieo45/IMG_0494.jpg)
Cut a refrigerator magnet to size, slap it to the battery compartment of the phone using double-sided tape, and you wouldn't even need the belt clip...
What you have is simple, and creative. Visually obvious what it really is, though. More of a "Rube Goldberg" phone holder now than a "Mickey Mouse" holder. LOL!
