W203 Tein Sus
Old Feb 15, 2006 | 04:30 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by eddie081
It's rubbing on the outside, I just had my fenders rolled but not as low as I wanted.
Maybe I need to have it trimmed/shaved?
Not as low as you wanted?
Well, your options would either be to roll the inside of the fenders back towards the body of the car or to have the edge of the fenders completely trimmed.
That's basically the only thing you can do. Otherwise, you'll continue to rub.
Old Feb 15, 2006 | 04:51 PM
eddie081's Avatar
Well I have 9.5 rears with +35mm offset. What I want to do is to tuck the rears like LorinzerCclass which he has 10's in the rear.
I did roll the rear fenders where the body shop fold it in.
If I want to shave the rear what is the cost, the body shop says it needs to repaint the fenders.
Thank Drex
Old Feb 19, 2006 | 01:30 PM
MiKeSSw203's Avatar
From: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
No one will have Tein coilover for W203 till mid-late Feburary. TEIN USA it self's out of stock till then.
http://www.tein.com/stock/sm-benz.htm
I just checked the Tein site and the Basic's are still out of stock. Just wondering if anyone knew when the next batch will arrive??
Old Feb 20, 2006 | 01:20 AM
drexappeal's Avatar
Thank Drex
You shouldn't. The portion that they folded in is what they would normally cut. If you're still rubbing with that, it's probably rubbing on something other than the outside. Check your tires to see where the rubbing is taking place. You should be able to see approximately where it is occuring.
Old Feb 24, 2006 | 09:41 PM
DRKC240's Avatar
'02 C240 + '03 ML320
Right. I just ordered mine today. The shop called Tein direct and the next shipment is due to the US on March 17th. Add another week to inventory and send to the shop, so I am looking at the end of March. Not thrilled, but I made the decision to go with it. BTW, $1170 installed, which is compareable to what I have seen others pay (I'm on the east coast).
Old Feb 24, 2006 | 09:43 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
congratz TEIN Basic will be very good.
I just put TEIN SS on my own car as well.
Old Feb 25, 2006 | 03:55 PM
  #32
electromethod's Avatar
Honda Grom
After reading this thread, I am concerned about rubbing. Has anyone with 8.5 fronts and 9.5 rears 35mm offset had any rubbing with the teins? IE... have you had to use spacers due to the teins?
Old Feb 25, 2006 | 04:27 PM
  #33
eddie081's Avatar
I have +35mm Rear on 9.5 with rolled fenders still rubbs. I am not sure if they rolled the fenders properly
I am going to bring it to another shop soon to see maybe they can be shaved
BTW: If you have a Sport Sedan it's rolled from th factory already from what the body shop told me. I have a 2003 C230 SS
Ed
Old Feb 25, 2006 | 06:38 PM
  #34
drexappeal's Avatar
Ed
Yes, that is correct. Mine are rolled in the rear already. Thing is, did you confirm that the rubbing is coming from the outside?
Old Feb 25, 2006 | 11:48 PM
  #35
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I have 19x10 in the rear with et35 (Carlsson 1/16). The rear quater panel is rolled and TEIN SS set to lowest in the rear. No more rubbing issue.
Old Feb 25, 2006 | 11:49 PM
  #36
Honda Grom
yah but us 2003 models got screwed in the sense that we got **** suspension etc...... wouldn't suprise me if ours weren't rolled.
Old Feb 26, 2006 | 01:29 AM
  #37
eddie081's Avatar
I had some white paint on the outside of the tires.
Does anyone have any pictures underside of the rolled fender?
FrankW: 19x10 wow, 35et nice, did you rolled the fender or just the factory rolled?
Ed
Old Feb 26, 2006 | 01:32 AM
  #38
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
no fenders are pre-rolled.
Mine's rolled through a local shop long time ago. It was the same as any other C-class before I had it rolled.
Old Feb 26, 2006 | 01:54 AM
  #39
eddie081's Avatar
How many peeps can be in the back seat? I have one the other night and it rubbed on bumps
Ed
Old Feb 26, 2006 | 02:02 AM
  #40
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
fits 3 with no problem with the renntech springs.
Old Feb 26, 2006 | 04:40 AM
  #41
eddie081's Avatar
Maybe the shop that I went is not doing it right
Ed
Old Mar 20, 2006 | 09:16 PM
  #42
benzo-boi's Avatar
2008 C300 Sport Sedan: Panarama Roof, P2, Multimedia
Okay, I'm sorry but I'm gonna revive this thread.
I've had a question about the TEIN Basic coilover kit. Perhaps drexappeal can help me out with this one. What is the max in inches you can lower the car with the basics? On the TEIN's website it's confusing; I see ride height and ride height adjust range. What's the difference? I'm looking at BIGjohnny's picture and it looks good. I'm okay with the rim/tire flushed with the fender. He has the SuperStreet coilovers which should be the same as the Basics but just with ride adjustability right?
BigJohnny's car:
Old Mar 20, 2006 | 11:41 PM
  #43
drexappeal's Avatar
BigJohnny's car:
SS and Basics drop will be the same at lowest/highest.
Old Mar 21, 2006 | 01:39 AM
  #44
benzo-boi's Avatar
thanks drex. whats the max drop for front and rear?
Old Mar 21, 2006 | 02:00 PM
  #45
drexappeal's Avatar
Take a look at this link w/ my car on it. Max drop in front is indicated as 1.38 inches and Max drop in rear is indicated as 1.54 inches.
Remember, the reason that it is different numbers than the 240/320 is because of the measurement between the stock sport springs/TEIN suspension vs. the stock luxury springs/TEIN suspension on the w203. Different spring heights and overall weight of the vehicles.
LINK: TEIN suspension specs for 230 K SS
Old Mar 21, 2006 | 04:49 PM
  #46
benzo-boi's Avatar
I'm looking at bigjohnny's car, and it doesn't look like it only drops it 1.38 inches front and 1.54 inches in the back. If Johnny's car is what 1.38" and 1.54" look like, then I'm okay with that. Can you confirm drexappeal or anyone else.
Attached Thumbnails W203 Tein Sus-pict0335.jpg   W203 Tein Sus-picture-013.jpg
Old Mar 21, 2006 | 05:43 PM
  #47
drexappeal's Avatar
I just gave you what TEIN indicated, so it's possible that their numbers are a little lower projection than what actually can be done.
Old Mar 24, 2006 | 03:09 PM
  #48
tman88's Avatar
06 c230
ive been reading a lot on Teins and hopefully i didnt miss it in the searching ive done.. but if i get the tein basics or SS with 18's will the teins rub the tire without spacers? or is that only a 19" 235 problem?? thanks
2005 c230 SS.. soon..
Old Mar 24, 2006 | 03:40 PM
  #49
drexappeal's Avatar
It's all dependent on the wheel offset on the rims you choose. If chosen correctly, it's possible that you won't experience any rubbing. If chosen poorly (without proper research and consultation with a shop), it's also possible that they might rub.
Old Mar 24, 2006 | 07:28 PM
  #50
benzo-boi's Avatar
I just ordered the basic tein coilovers. I'm setting them up with 19" Brabus Mono VI with offset 45. Brabus gave me 16mm for the fronts and 10mm for the rear, for my 2005 C230SS This sounds off, but they're the experts, I guess.
