W203 Tein Sus
Old Mar 24, 2006 | 07:37 PM
  #51
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by benzo-boi
I just ordered the basic tein coilovers. I'm setting them up with 19" Brabus Mono VI with offset 45. Brabus gave me 16mm for the fronts and 10mm for the rear, for my 2005 C230SS This sounds off, but they're the experts, I guess.
The spacers make it about right. If you're getting the Mono VI's (I'm assuming 1 piece) and the offset is 45 (both front and rear), you take the 16mm front spacer, subtract from the 45 offset and you get 29. Same for the rear and you get 35. (F et 29 / R et 35). Sounds pretty close.
Do you have the rims already? If not, did you tell Brabus that you will be running on the TEIN Basic's because you definitely should have. Either way, there's always something that can be done to fix it if you have fitment issues.
Old Mar 25, 2006 | 05:29 AM
  #52
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
TEIN Basic are back in stock.
$890 retail our price $765 plus S&H and tax if applicable. And yes suspension is still on sale from various brands. ask me for quote in email or PM.
If anyone have not experience with the TEIN coils you will not regret it.
Old Mar 25, 2006 | 10:23 AM
  #53
drexappeal's Avatar
Frank, so you like them?...LOL.
Old Mar 26, 2006 | 04:52 AM
  #54
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yes sir...after driving few different suspension setup back to back. This is by far the best bang for the buck suspension. I think the only better one will be the PSS9 or KW V3.
Old Mar 26, 2006 | 11:58 AM
  #55
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
How would you compare ride quality to the stock C32 set up??? I have an '06 C230 and want to lower it but like the ride the way it is. I also assume that running 19"s makes some ride quality difference as well???
Can I also assume that this is a fairly easy DIY project. You should not need to compress the front springs if you are removing the entire strut, right?
Old Mar 26, 2006 | 05:13 PM
  #56
benzo-boi's Avatar
2008 C300 Sport Sedan: Panarama Roof, P2, Multimedia
I hope it'll work. i got the multi-piece wheels, don't think it matters much in terms of offset. They're all 45
Old Mar 26, 2006 | 09:23 PM
  #57
tman88's Avatar
06 c230
is this the ideal offset u r looking for? i was concidering buying the TSW but seems like a lot of trouble with the spacers. so if i were to get an iforge or work what would the offset id be needingsince i can make the custom ordered? does it matter if i get a 8.0 in the front or 8.5? or is it an offset issue not as much as width issue?
Old Mar 27, 2006 | 12:07 AM
  #58
SteveL1's Avatar
I think it's both width and off set. I'm still very confused on how to figure out what is needed to clear the big brakes and the coil overs with out using spacers...
Old Mar 27, 2006 | 01:07 AM
  #59
benzo-boi's Avatar
From what I've researched, for the '05 big brake calipers with 19x8.5 fronts and 19.9.5 rear, you need 32 or lower in the front and 35 in the back.
Old Mar 27, 2006 | 02:58 PM
  #60
tman88's Avatar
06 c230
so if i get a 30 up front and a 35 in the back i should be good to clear all coilovers? sorry if it seems like ive been askin the same question. just wanted to not make a mistake and have to end up getting spacers anyways. thanks!
Old Mar 27, 2006 | 03:15 PM
  #61
jac1502's Avatar
2017 E550 Coupe
With spacers it makes my front offset 28 and my wheels clear by 1mm
35 offset plus 7mm custom spacers my car is an 06
Old Mar 27, 2006 | 03:23 PM
  #62
tman88's Avatar
06 c230
sounds like 27 to be safe.. and 35 in the back would be fine? i havent read any issues with the rear rubbing the coilover, just the clip and fender.. i went to the benz dealership and they wanted 33k for a 15k 05 230k and a brand new 06 was like 34.. interesting huh! hehe. i think i'll stick with an 06.. u mind tellin me how much u got ures for? u can PM me if u dont want to say in in the thread. thanks!
Old Mar 27, 2006 | 03:38 PM
  #63
eddie081's Avatar
That is the offset I have ET30 front and ET35 back it clears the Tein coilovers
Ed
Old Mar 27, 2006 | 03:52 PM
  #64
SEXSPHERE's Avatar
//WALD C320 Magnifique [sold], BMW Z4 3.0i 6spd[sold]
Going to get my H&R coilovers installed on thursday
Would 32 offset in the front clear the coilovers? 235/35/19
Old Mar 27, 2006 | 05:44 PM
  #65
tman88's Avatar
06 c230
sexshere,
if i am reading correctly that will not clear the coilovers. but obviously i have been the one askin all the questions so maybe im not the man to be giving u advice
ed,
im assumin u r running 245 in the front? which brand tires.. ive been told different brands have different shapes. thanks!
Old Mar 29, 2006 | 06:00 PM
  #66
DRKC240's Avatar
'02 C240 + '03 ML320
Thumbs up Tein Basics Installed
After waiting almost a month for the coilovers to get back in stock, I finally had them installed yesterday. Overall, I am very happy ! The drop on the 18s looks good without being slammed. The ride is noticeably stiffer, but not excessive. Handles much better. No more excessive roll and it takes the curves and corners great now. A before and after for your enjoyment...
Attached Thumbnails W203 Tein Sus-after-medium-.jpg   W203 Tein Sus-before.jpg
Old Mar 29, 2006 | 06:03 PM
  #67
Blake P's Avatar
'09 A4 S Line
I like the second picture...raise it back up!
Old Mar 29, 2006 | 06:11 PM
  #68
DRKC240's Avatar
Yea, I know - had 'em reversed for a minute Think it is right now!!
Old Mar 29, 2006 | 06:21 PM
  #69
drexappeal's Avatar
Looks much better. Congrats on the purchase.
Old Mar 30, 2006 | 12:47 AM
  #70
SteveL1's Avatar
Are those 18" Bremmas???? Looks awsome with the drop. Any other pics showing the wheel lip....yae I know there's not much, but would like to see before ordering. Thanks! Oh, and do you need to run spacers in frt?
Old Mar 30, 2006 | 10:47 AM
  #71
DRKC240's Avatar
Not Bremmas
Sorry, no. Those are 18 x 8.5 replicas from Lakeshore Wheel. While a lot of people might scoff at the replicas, I am very happy with them and have had a lot of positive comments from people who see them in person. Lakeshore was very good to deal with too. No spacers needed.
At work now, but I will get some pics of the lip later and post them tonight.
Old Mar 31, 2006 | 04:57 PM
  #72
DRKC240's Avatar
My lips
... Any other pics showing the wheel lip....yae I know there's not much, but would like to see before ordering...
Do a search on Ebay. Once i found them I looked up their website and called for a wheel/tire package.
Attached Thumbnails W203 Tein Sus-dscn1028-small-.jpg   W203 Tein Sus-dscn1031-small-.jpg
