Engine Died on the Freeway.
Old Aug 8, 2002 | 06:05 PM
dontwakemeup's Avatar
C230K Coupe
hi totita,
Can you remember what sensor was replaced? We could really use that info, I hope you have pinpointed the problem!
Old Aug 8, 2002 | 09:00 PM
mleskovar's Avatar
'17 Jaguar XF
"I can still smell a gas odor coming from underneath the car."
You should not smell gas outside or inside the car. Take it back.
Old Aug 15, 2002 | 10:45 AM
Chicago C's Avatar
C230
I experienced the same stalling problem, at 80 mph on the highway in moderately heavy traffic. Engine just died. Starter would turn, but no start-up. Tank had 1/2 left. Hot day. No malfunction displayed. After sitting for 1 hour waiting for the tow, it started right up again with no problem. One dealer found no fault indicators and could not diagnose any problems. Home down dealer (larger, more experienced) diagnosed it as a short in the "transmission control module" and replaced that part under warranty. No problems since.
Old Aug 15, 2002 | 10:54 AM
kompress's Avatar
Did anybody have this problem with an auto or was it just with the manny?
Old Aug 15, 2002 | 11:08 AM
Chicago C's Avatar
C230
Mine is an automatic.
Old Aug 15, 2002 | 11:10 AM
raymond's Avatar
C230K
We had the problem with an auto.
Old Aug 15, 2002 | 01:17 PM
  #32
C230K Coupe
I hope the transmission control module exists in the manual!
Old Aug 16, 2002 | 02:17 PM
  #33
CHARLIEBROWN's Avatar
w203 kompressor
i have a manual with stall... hold the mayo
charlie
Old Aug 19, 2002 | 01:20 PM
  #34
Big Dog's Avatar
C230 Coupe
Had the same problem with mine (auto) after coming to a stop and attempting to accelerate. This occurred after about an hour of 75-80 mph driving.
Dealer could not determine source of problem until MB arrived. Ultimate conclusion was to replace transmission contol sensor. No problems since -- about three months ago.
Old Jul 22, 2004 | 11:20 PM
  #35
pookie's Avatar
2013 c300 4matic, 2002 c240
Originally Posted by vadim
i just filed my complaint about my car shutting off while driving.
btw, the correct address is:
http://www-odi.nhtsa.dot.gov/ivoq/
Old Aug 22, 2004 | 02:39 PM
  #36
clk_jp's Avatar
CLK 430 - Magma RED, 1999
CLK 430 with similar stalling
I expereinced the same issue ... waiting on a traffic light in 105 temp. as I started to accelerate all lights on the dash came on and the car just died. About two traffic signal cycles later it came on as if nothing had just happened. Dealer hasn't been able to identify the issue because no codes are generated and it never does this when visiting the DOCTOR!
