Sprint Booster - Car behaving like a monster and hungry for speed
Old Jan 5, 2018 | 10:01 AM
  #701
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Originally Posted by pakka
Well, I agree with the guy. I put it on my CLK200 when it was 57K on the clock.
Dealer explain me that the only think this gadget is doing, is to cheat the ECU from idle to 4000 revs changing the butterfly angle for quicker response.
No power increase just the feeling that you have a wire and not an electronic controlled throttle.
However, after 100K some related components start to fail. 1st the throttle body, then TPS, then MAF.
I did reset ECU and all was OK, but after a while problems again.
To sort my words I test all combinations with or without SB and above components.
As a result I can say that SB after 100K and so km's causes problems to throttle body ( unstable idle and misfiring on a highway) so I decide to take it out. But no complain for the time was on the car.
I am betting your sprint booster has an issue if you removed it and everything works. If you replaced it with a new one it would probably work like normal. Also your dealer is right.
Old Aug 9, 2023 | 10:28 PM
  #702
tkid's Avatar
C230K M271 CL203 2003 model
Found this to be a good assessment of the SB unit..
https://www.evilution.co.uk/wp-conte...intbooster.pdf
Old Aug 10, 2023 | 08:48 AM
  #703
insame1's Avatar
This is all you need to read out of that document and what i have been saying the entire time.
"Conclusions
The Sprint Booster is a simple amplifier that multiplies the accelerator pedal sensor signal, making the accelerator pedal more sensitive. It does not eliminate any significant delay in throttle response, nor does it greatly improve acceleration figures. It does not change the adaptive throttle control programming of electronic throttle control vehicles. It does change pedal “feel”. This change in feel is interpreted by some as improved throttle response, acceleration, and a change in adaptive throttle control programming. Considering what it actually does, it is expensive."
Old Aug 10, 2023 | 09:01 AM
  #704
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
Originally Posted by LexBrett2
I just want to chime into the discussion. The only people that don't like sprint boosters are the know-it-allstate who in fact have never even used it!!
SB is an amazing device.
Absolutely love mine, when I turn the switch off it's like night and day.
Old Aug 10, 2023 | 12:58 PM
  #705
insame1's Avatar
i got a bridge ill sell ya lol
Old Dec 31, 2024 | 07:51 AM
  #706
yugoport's Avatar
w208 230k
I know it has been a while but I would like to thank you for sharing this, very interesting.
Old Jan 1, 2025 | 09:31 PM
  #707
Petethepug's Avatar
90 VW Corrado g60, 07 New Beetle Vert triple white & 09 Escalade ESV Plat LOL!
@tkid
I’ve done that before. Post # 702 was worthy enough to sign up for the forum just to make one post to say thank you for the information.
Old Apr 19, 2025 | 03:12 AM
  #708
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Do rhey even still sell these?
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
