Coupe aquaplanning
I had tried different brands of tyres like yokohama, goodyear f1, michelin pilotsport, continental sporcontact2, ...
All tyres do the same. My tyre dimensions are 225r17. I think they are not so big that can produce this results. I have also an audi A4 with 245 tyres and it does not do the same.
Also the car is unstable in bumpy roads.. I had the car to mercedes workshop and they replaced the ESP and central processing unit but it keeps the same.
Any ideas?
Today, i was about 70km/h on the highway and i got all kind of cars passing through mine (they were at about 120km/h).
Are your tires bald?
Are they loosing air pressure over time?
Is the suspension damaged?
Are the wheels true?
Don't give us 'my a4 was blah blah blah' crap. Your car is either damaged in some way, defective, or you can't drive.
Seriously, you should come to the US and attend a competition driving school with wet skid pad training. It will improve your skills for road driving, and unlearn all the bad habits you have picked up.
My friend took a class and discovered the problem with his Porsche was the nut loose behind the wheel.
Now it started the rain period. It has rainned alot since since last year and just now i'm having this aquaplaning sensation.
Mercedes mechanics said the car had never had an accident or the chassis is in good shape. I don't know what to do..
Thank you for your reply.
My tyres are ok. I've tried different types of brands. The pressure is ok. I've tried also differente pressures on each tyre. The suspension is like new (at least it's what they said on mercedes workshop) and the wheels are original 17" mercedes benz wheels.
Any ideas?
When i drive a friends coupe evolution that is just like mine (wheels, shockabsorvers, etc) and it has nothing to do with mine. It's incredible stable. So it shouldn't be a driving problem...
About the speed. The car slides even at very slow speeds.
Please ask the factory rep in your country to get involved, and assist the dealer in making your car safe.
If the car is actually hydroplaning, then it most likely has to do with the tires. Tread, and tread life, condition of the tire, and tire pressure are easy to check. If these check out, and your tires are designed for wet weather, then my next step would be to check the alignment and suspension.
