FEELER: CLK55/SLK55 Brake setup group-buy
Old Apr 5, 2006 | 08:07 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by Russell Stevens
Frank,
Is this price different then what we talked about for the rear? If this is a good price for the rear four piston with cross drilled rotors and pads Im in for the rears. As for fit I had to put my 17' seven spokes on while I waited for my 5mm spacers for my front c32 set up and it fit, with just a hair to spare. I havent tried my spare yet but I can try it on, and check if people are interested in knowing. I think the rotors are the same diameter on four piston set up and six piston but someone will have to varify that??? The caliper could be a little larger too ??
your set's going out tomorrow morning I've send you a PM.
Old Apr 5, 2006 | 08:08 PM
jnolte's Avatar
744 C36 AMG,040 C43 AMG, CLK55 208, CLS55 IWC, CLK500 Rocketbunny widebody
hmm i got brand new C32 brakes installed on my C43 for under 1000
Old Apr 5, 2006 | 09:01 PM
BrabusClK04's Avatar
W209
im interested in the rear. Let me know, Thanks!
Old Apr 5, 2006 | 11:45 PM
kickR's Avatar
'14 CLA 45
i would be in for the rears ... if those calipers just wouldnt look different than my front ones
Old Apr 5, 2006 | 11:58 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
so we got. any one else?
1. BrabusCLK04
2. KickR
Old Apr 5, 2006 | 11:59 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
good for you. mine was FREE.
Old Apr 6, 2006 | 12:19 AM
  #32
kickR's Avatar
'14 CLA 45
1. BrabusCLK04
2. KickR
nah frank, you gotta read again.
i only wanted to rears, because i dont like that my rear brakes look so tiny now that i have the 19". but then again you said that the rear ones in this group buy arent drilled, right?
also i wouldnt want a different caliper in the rear (or however its called - the thing with the AMG on it in your latest picture) because it would look stupid. i would then have to go with the fronts too and im happy with my fronts.
Old Apr 6, 2006 | 12:54 AM
  #33
Wallance's Avatar
I am wondering if the brake kit fits the SLK350 too? are they the same thing?
Old Apr 6, 2006 | 12:57 AM
  #34
jnolte's Avatar
does the rear fit on a w202?
Old Apr 6, 2006 | 12:59 AM
  #35
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the C32/55 rear's not drilled. The CLK55/SLK55 one is the one in the picture.
you can always paint them.
Old Apr 6, 2006 | 01:01 AM
  #36
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yes, 2005-2006 CLK55 uses the same brakes as the SLK55. The brake kits would be a bolt on for the SLK350. You will need at least 18" to clear the front caliper tho.
Old Apr 6, 2006 | 01:04 AM
  #37
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
that I am not sure. I believe the bracket can be modified, but if it works you might need a bigger brake pump. I've heard people put full Brembos on the W202, but the pump doesn't have enough power to bring fluid to both front and rear.
Old Apr 6, 2006 | 01:12 AM
  #38
Wide w203's Avatar
are you sure the clk55 and the slk55 rear 4 piston brakes will be a direct bolt on? i dont totally remember but i think when i did it before there was a few modifications needed. i could be wrong (did it over a year ago) but for some reason i remember that
Old Apr 6, 2006 | 01:16 AM
  #39
white_w203's Avatar
is SOLD
i think the rear is a direct bolt on, but the front probably needs some slight modification.
Old Apr 6, 2006 | 01:21 AM
  #40
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
dave, i thought urs was from the E55 lol.
Old Apr 6, 2006 | 01:54 AM
  #41
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
frank would that fit a C32 for the rear?
Old Apr 6, 2006 | 02:43 AM
  #42
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yes it would. Few people already done it. I think pictures can be found from search in the C32/55 forum. I don't remember who it was tho.
Old Apr 6, 2006 | 01:04 PM
  #43
pshek's Avatar
2003 C-Class Sportcoupe
Frank, any info on the rotor thickness?
Old Apr 6, 2006 | 05:51 PM
  #44
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
thickness for rear's about 2.5cm.
