Easy LED Tail light mod
Old Apr 5, 2006 | 07:04 PM
  #51
e1000's Avatar
a quarter mile at a time
I can't believe this. I measured my stock bulbs and I swear they were 44mm. Just got the 44mm bulbs in and they are wayyyy too big. Dosen't even fit in the housing.
Old Apr 8, 2006 | 01:44 AM
  #52
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
so I got BOTH the 39mm (first order) and the 44mm bulbs. the 44's are obviously too big, but the 39's are too big too! they won't even light up when I put them in!
I thought I could use them for my interior but they sucked! it was waaaaaaaaaaaaaaaaay dimmer than normal and the "white-ish" wasnt' that noticeable so I put the stock bulbs back in... (the interior uses the 44mm, the 39mm's can fit but very loosely)
I think the 36mm (the next smalled down) wouldn't be the right size for the license plate bulbs... oh well.
Old Apr 8, 2006 | 02:07 AM
  #53
c230kracer's Avatar
cl203 Sports Coupe
Ok well....those might be dim but they wont MELT the plastic surrounding it like it did to my tail light housing....it was so BRIGHT and perfectly WHITE, i will post up some pictures for you guys to see how bright they are....but the thing is...THEY GET TOO HOT! iono what to do with the housing....i tried finding some kind of TAPE or...Metal Bracket that i could put in there to resist the heat from the bulb....well i'll be back soon with a picture of how nice they would have been and these Bulbs are "Raybrig" name brand i think? if thats how you spell it...im using them for my interior and they are SUPER bright and perfect. pictures comming soon!
Old Apr 8, 2006 | 02:53 AM
  #54
c230kracer's Avatar
cl203 Sports Coupe
OK so here are some pictures of the Bulbs for my Interior, they are also Raybrig Name brand lights...they fit just a little smaller than the original size.
These pictures dont really show how BRIGHT they really are, but trust me, its really bright heh
Oh and if your wondering what all that stuff is on my dash, well its just my little iPod mod, i just bought the universal dock with the remote and double sided taped it onto the dash and connected it straight to my BRAIN unit for my monitor. Its awesome using the remote to change songs now.
Attached Thumbnails Easy LED Tail light mod-img_2658.jpg   Easy LED Tail light mod-img_2661.jpg
Old Apr 8, 2006 | 03:00 AM
  #55
c230kracer's Avatar
cl203 Sports Coupe
And now for some pictures of the license plate lights....like i said...i cant leave them on too long(about 5 minutes before it starts to burn the plastic housing around it haha, its pretty bad....) they are super bright though, cant wait to find something to put inthere so i can use these bulbs! Give me ideas guys! Thanks
So first picture is a comparison from the original bulb on the right side and the super white on the left. Second is all super white bulbs and the 3rd is just a side shot showing how bright it is...i mean on the road...it seriously lights up the road behind me including my super bright tail lights too
P.S. I was just wondering....Does anyone remember me asking them to help me rewire my radar to get rid of the wire comming from the power port? I think it was Tony? im not sure...this was back when we met up at Irvine.
Attached Thumbnails Easy LED Tail light mod-img_2667.jpg   Easy LED Tail light mod-img_2672.jpg   Easy LED Tail light mod-img_2675-copy.jpg
Old Apr 8, 2006 | 06:45 AM
  #56
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
To use the LED plate lamps, at a lower power, there are three choices.
One is to put a power resistor in series with the lamps, to drop the current and brightness. It must be sized, based on the current and power to do the job and not burn up too.
Another is to add a constant current circuit for the LED lamps and tune it to the desired output. Not overly complicated, but it requires a small circuit board.
Last is to rewire the plate lamps so they are in series, each sharing half the 12 volt power. This may be the best option.
Old Apr 8, 2006 | 12:09 PM
  #57
c230kracer's Avatar
cl203 Sports Coupe
these bulbs aren't LED's though....i wish they were because i wouldn't like the install the load resistors because they heat up too much...
Old Apr 8, 2006 | 12:35 PM
  #58
e1000's Avatar
I wasn't going to change the interior bulb (kinda like the soft light of the regular bulbs) but those pictures make me want to do it. I'm also thinking of the puddle light on the bottom of the door that lights up when you open the door. Looks NICE
Old Apr 8, 2006 | 08:10 PM
  #59
e1000's Avatar
BTW here is a shot when it was super sunny outside.
The trunk LED's do actually look more orange than the two corner brake lights in sunlight. Intensity wise, they were pretty similar with the trunk LED's bein slightly brighter.
Old Apr 15, 2006 | 09:57 AM
  #60
mbbodytech's Avatar
04 C320 Coupe MT
Originally Posted by drexappeal
Mike, what happened to your project?
Hey Drex,
In the end, I just couldn't find a way to make it work to my liking. So I had given up on the idea, until this post! I just received my parts in the mail, so if I can make some time today I'm going to put these suckers in! Can't wait!!
For everyone else, I had started a project to create my own LED lighting elements using parts from a 211 LED taillight element. I Disassembled the element (prying and pulling it apart) and then put all of the LEDs back on another circuit board, soldered everything together to make it work in a shape that would fit into a heavily modified C coupe taillight. And it worked, however the problem is that in daylight it looked like a bunch of dots, and the light was not reflected like it needed to be (because of the fact I can't make a nice housing like cars that have LEDs from the factory have that reflects all of the light rearward) The setup worked great in anything but broad daylight.
However, I did learn some things about making them work. I am going to apply this to wiring in my new bulbs, and can't wait to see the result.
One concern I had at first about the Coupe taillights was that the bulb is mounted vertically, and would there be enough clearance. Thanks to Eric taking some pics, I had the suspicion that there was. And, I test fitted the bulbs when I got them last night and they do fit! So, all that's left is the wiring. Stay tuned, Coupe owners.....
Old Apr 15, 2006 | 12:07 PM
  #61
e1000's Avatar
Originally Posted by mbbodytech
Hey Drex,
Good luck and post some pics!!!!! I hope your results turn out as well as mine did.
Old May 10, 2006 | 08:48 PM
  #62
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Hey Drex,
Too bad you couldn't make it work completely, but hopefully these bulbs helped you move forward to making it work, Mike! (Sorry, just saw your post today for the first time).
Any updates?
