Engine sound and supercharger ?
Old Aug 12, 2002 | 05:47 AM
latent's Avatar
Question Engine sound and supercharger ?
Hi
Can anyone tell me what speed tfoes the supercharger cuts-in ?
Or is it operational all the time.
This is my first MB and I wondered about the general sound of the engine - like a high pitch purring when I accelerate. I assume this is normal?
I know this sounds a little crazy, but the at gentle acceleration the car sounds like an electric vehicle!! Anyone else sense this?
Old Aug 12, 2002 | 08:27 AM
Jerry MB230K's Avatar
Noises
The engine is noisy, and the noises are atypical. When starting the engine, some people have said it sounds like a lawnmower. It seems to be the noisiest during the first few minutes after you start it. Some people have a clicking noise also.
Old Aug 12, 2002 | 08:32 AM
Response to "LATENT"
Latent,
I believe the supercharger goes on when you start the engine, but you only feel the effect ( extra acceleration ) at 2500 rpm and above.
I've driven electric cars, but I don't see any similarities. Electric cars are always quiet, the 2.3 is very noisy !
Old Aug 12, 2002 | 08:40 AM
mdp c230k's Avatar
2002 c230k
The supercharger is always on, it is directly related to engine rpm, the higher the rpm the more you'll here the supercharger whine.
Old Aug 12, 2002 | 08:53 AM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
yeah I can usually really begin to feel the SC kick in about 2500rpm, thats when it makes enough boost to feel with my butt dyno. Hopefully with the addition of a pulley the "kick-in" point will be lower on the rpm scale, allowing for not only more hp but quicker acceleration.
On a side note, isnt the throttle actually throttle by wire. If so then couldnt you increase the throttle response electronically? So it is more receptive to pressing the gas pedal?
Old Aug 12, 2002 | 11:02 AM
If you have auto xmission and you step on the gas, all you're doing is sending a signal to the computer ; if the program allows, then you accelerate. That's why sometimes this car is dynamite, and sometimes it's sluggish.
Old Aug 12, 2002 | 12:06 PM
Buellwinkle's Avatar
While the supercharger is always spinning, the wastegate is open most of the time releasing unused pressure. At full throttle the wastegate closes for maximum boost and the S/C whine will be more pronounced, specially with a pulley kit.
Old Aug 12, 2002 | 12:16 PM
C230 Sports Coupe
i dont know much about wastegates. Is this an electronically controlled thing? If it is could a chip cause it to close lower in the rpm band thus making more power lower? or is it a physical component that cant be changed. Even if tweaking the waste gate doesn't offer more peak power couldnt it raise the torque curve and make it flatter, for better acceleration.
Old Aug 12, 2002 | 12:51 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
S/C don't have wastegates - turbos have them. Bypass valve is what's used in our Eaton M45. The valve opens to bleed the excessive air pressure back into the intake right past the air filter.
Old Apr 27, 2013 | 04:10 AM
p.willy's Avatar
2003 Mercedes Benz C240
Posted from Mbworld.org App for Android
