Need Help! What happened with that brake noise?
by the way, when i step on the brake, it has some weird noise.. my friend told me probably the brakes are gone but i got my brakes changed not too long ago.. how come the noise is still there? my warrenty was just over this Feb.. can anyone tell me whats wrong with my car? thx!
2002 C230k coupe you can do wheels, add-on bodykits, lowering springs, exhausts for exterior, and DVD indash if you are into that.
as far as the brake noise it's most likely it's just temperary. If you just changed it there might be tiny rocks stuck between pads and rotors OR it can be the weather sometimes during cold weather my brakes would screech. How long ago did you change the brakes?
mine ended up being the rear brakes, now all is fine.
good luck with that.
