Caliper covers??
I would run the other way. Get a carbon fiber door sill cover if you feel the need for a bit of CF style.
i suggest not getting them because they're foam and require adhesive to stick on, like said above, ur calipers gonna heat up
http://cgi.ebay.com/ebaymotors/Red-S...1073QQtcZphoto
warning---if you bid and dont pay, this guy will leave a strike.
i learned the hard way....i was gonna buy, but i decided they were too cheap for $50.
Another thing, I don't think F1 cars have brakes that look anything like these. The advertisement is very misleading.
Instead of a group buy, we should have a class action lawsuit!
I wouldn't put these on my car even if you gave them to me for free.
The rear brake shape does not permit lots of surface area to adhere the cover, unless the cover has a complex interior shape that conforms to the caliper.
The concern I would have is the adhesive failing during vehicle operation. The rotational inertia would then be transferred, from the interior wheel surface, to the cover. It would then be possible for the loose high-speed cover to damage something important, like the brake line. That event could then cause problems for vehicle operation.
The image is my freshly-painted rear factory brake on my MY 05 C320 Sports Coupe with six-speed, as shown in my rear brake pad replacment post.
http://cgi.ebay.com/ebaymotors/Merce...16373143QQrdZ1
MERCEDES BENZ AMG Brake Caliper covers, complete set includes L+R, 2 pieces.
Material: Ceramic coated Fiber, Temperature tolerance 1300F (700C)
Installation: can be glued with termal-resistant silicon glue or bolts with slight drill to calipers
Fit for Rim size 16" or larger, an instant upgrade for cosmetic apperance without spending thousands $$$.
