SOCH vs DOCH
Thx
Single Over Head Cam SOHC
Double Over Head Cam DOHC
And yes, having 4 valves instead of 2 or 3 will allow the engine to make more power at higer engine speeds because it can get rid of exhuast fumes out of the cylinder better, allowing you to have more fresh air to use in the combustion process. That is the whole idea behind "Vtech" and the likes. The have variable cam timing to change when the valves open and close because at higer RPMs opening at the same point as at lower RPMs is not efficient in expelling exhuast and replacing it with fresh air/fuel.
SOHC is design to make more Torque
DOHC engine usually has higher Redline compared to SOHC
DOHC engine cost more to make than SOHC
The only high revving SOHC engine that I know is probably the 3.2L VTEC engine in the Acura TL. Pretty amazing engine if you ask me.
Performance car usually have DOHC setup, while SOHC is cheaper to maintain and probably more reliable due to less moving components.
As for more torque from SOHC...not really. Torque is a function of stroke and displacement x number of cylinders. Big displacement, long stroke and 8 cylinders always means gobs of torque...regardless of how many cams an engine has. Where OHV and SOHC comes into the torque realm has to do with air flow. Steady flow, high velocity air intake from a two valve design tends to emphasize torque...but a lot of that is by design...because two valves flow poorly at high rpm- where you make all your HP...so the engineers try to enhance the torque if the engine can't spin high...and usually it can't spin because of the design favoring torque.
The most satisfying engines for daily driving all have lots of torque...torque is what gives you that grunt, that hard pull in gear accelleration.
Engine Specifications
4.6L 260 hp V8 - 4.6L 305 hp V8
Horsepower - 260 @ 5250 RPM - 305 @ 5800 RPM
Torque (lb-ft) - 302 @ 4000 RPM - 320 @ 4200 RPM
Valves/Valve Config - 16/SOHC - 32/DOHC
Displacement (cc) - 4605 - 4605
Bore X Stroke (in.) - 3.55 X 3.54 - 3.55 X 3.54
Compression Ratio - 9.4:1 - 10.1:1
Fuel Type/System - Gas/SEFI -- Gas/SEFI
Turbocharger - No - No
Supercharger - No - No
Its a decent real world comparo, since all is the same but the compression ratio, but thats not that huge of a difference... Its just to give you an idea...
BTW, OHC, and DOHC designs are nothing new. They date all the way back to the 1920's, perhaps even earlier. Complexity and Cost kept them a niche technology until the late 70's and early 80's.
I will say that I think that SOHC cars on average get better fuel economy. I could be wrong.
DOHC cars are definitely higher revving and more inclined to rev than SOHC cars.
Many people are wondering why their expensive cars have SOHC and think it's a compromise to DOHC, personally I can't really tell the difference.
We should have a poll, which do you prefer?
SOHC?
DOHC?
Either?
P.S. I'll take Rotary engine over all of the above~
Ed.
Thus is why BMW engines had it over Merc Engines. Using their Double Vanos, BMW could keep the low end torque & efficiency, while still reving to get the HP.
Now that Merc has a decent platform, the score should be much more equal.
Note from 2002 the 230 was a dohc, with independant Variable Valve timing on intake & exhaust. I think Merc saw they had to play catch-up back in 2000, and the 1.8 was the development mule for the head.
You posess some knowledge you would like to share????.......or you just like to comment about other's?
The M271 had it on exhaust and intake. I don't really see the M271 as anything but a long overdue replacment for the M111. I prefer the M111(m271 didn't deliver on the performance), but standards for things like fuel economy, NVH, and emmisions always are marching forward.
