ring pulley on m111
ring pulley on m111
is anyone here running a kleeman or carlson ring pulley on an M111 motor? i have heard all the horror stories, from third parties and would like to hear from any firsthand users.
1 Post
2002 C230 Coupe(M111)
A brand new ASP pulley is still pretty inexpensive.
Originally Posted by Outland
So, if youve heard the stories, why are you even interested anymore?
Thanks/Al
because they have all been hearsay. id like to hear it from someone who actually had a problem; as opposed to typical low grade mbz tech about the guy who herd it from his sister's boyfriend.
to date there has been no logical explanation for the alleged blower failures.
1 Post
Do a search...the ring pulley isn't even produced anymore...that should speak volumes about its serviceability. Its not the supercharger you have to worry about...its that ****ty little ring pulley coming loose or misalinged. It can shred a belt or come off entirely.
Spinning the Eaton faster doesn't kill it. The SC on the M271 is running 11psi...that's more than an M111 is running on a car with the enlarged crank pulley. Do you think MB would have put the car on the road if 10 or 11 psi of boost would destroy the SC?
The amount of time you spend in the extra revs is so little, and even if you wear it out a little faster...so what. A Roots type blower is cheap and easy to rebuild.
Youre obviously a little on the cheap side if youre even considering the ring pulley. An ASP is only 600, 300 if you return the core, and its based on the stock MB pulley- no dampner or balance worries there. Can't get any better than that.
1 Post
Originally Posted by aecasasus
Any links or websites for more info?
Thanks/Al
Thanks/Al
Won't do you any good... the newer engine like you have doesn't take well to more boost...the ecu kicks the timing backinto last year...and you don't make any extra power.
So far, the only ways to get around that is using the Kleeman K box, which alters the signals coming to and leaving the ECU, or a custom ECU tuning...
OK, I'll be the first to put it out there...you sound like an idiot.
im gonna answer your question with a question. Do you think mercedes would have put the car on the road with a disintegrating harmonic damper hub, or dozens of software bugs, or known bad sway bar driving links, or a variety of failure prone front suspension bushings? If you'd used the search tool i'm sure you would find a variety of problems in these cars that the factor has produced in tens of thousands of units. So sure...mbz can make dumb engineering decisions. Have you looked at the cup holder recently?
Who is the bigger idiot...you have three of the things. You are the one with "MBUSA sucks" in your sig block.
I asked because i have a cnc turning center in the shop behind me, and a bunch of 14" square by 1.75 thick 2024 aluminum billets behind me left over from an aerospace prototyping project, and i'd rather tinker with it than throw it out.
Thanks for your incredibly insightful tech.
1 Post
hmm...then i suppose you'll be the first to be told to suck it. Its really not appropriate to lash out at strangers just because your daddy never told you he loves you..
So sure...mbz can make dumb engineering decisions. .
Have you looked at the cup holder recently? .
Who is the bigger idiot...you have three of the things. You are the one with "MBUSA sucks" in your sig block..
dude...you are the one who thinks cuervo is good tequila.
huh...did you consider the effect of weldment to the hub, and the hydrogen embrittlement that occurs in the heat affected zone around the welds? Did you consider the fact that the part can's be properly re-heat treated after weldment to normalize it due to the rubber liner? If you think there are no worries, you might want to go take a materials science class..
A permanently attached ring would fair much better than the clumsy set screws that the Kleeman ring used.
www.aspracing.com
I guess I'll go the ECU upgrade way!!!
I think he should put it on and see for yourself if it's good or bad. So I won't even comment on the rings I've seen, had in my hand and help install because you wouldn't believe me because I personally did not have it on my car. Go for it, it will be an outstanding experience for you. It's still available from Kleemann in Denmark, not U.S. As it turns out, the people that like it and still have it on drive W203 C200. In 4 years I have not heard of anyone with a W203 C230 that still has it on and that's across 4 forums so you may not get much of a response.
You should probably sign up for that class as well... your comments up there don't really make much sense. And unlike Outland... I am a metallurgist.
www.aspracing.com
Other than that, wait a few months, there's a couple companies working on some right now.
1 Post
Thanks for the info Outland!!!! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I guess I'll go the ECU upgrade way!!!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
2002 C230K, 2013 BMW 328, 2015 BMW X5
Come now boys, the sandbox is big enough...
Now, who needs a coffee?
1 Post
Originally Posted by emrliquidlife
Outland, you were a bit harsh. ?
But I guess I have gotten used to your practical and direct communication.?
