DIY Changing Fog lamp Bulbs & W203/CL203 Fog Lamp Thread
#51
2013 c300 4matic, 2002 c240
Originally Posted by DACHIGGA
$70 bucks, what a rip.....
#52
ok, i ordered the bulbs and now just waiting for them. but, i decided to replace the broken foglight lens today instead of just doing it all at once when the bulbs came.
well, i replaced the lens. the old-bulb was shattered with the lens. no error code was reported when fog lights was switched on. i removed the bulb and left the foglight's wire just dangling there. i put everything back together.
i go out for a drive and the a/c which is usually on auto blows a bunch of air till the temp and good and automatically reduces it. however, this time, auto turns off immediately after a 1 minute. i try it with the recirculation. same thing. with neither, the a/c works but i get a weird smell.
i go back and open everything up near the passenger side foglight. i do not see any problem.
before i assume it is a seperate issue with the a/c as stated on the forum and the RFM, i am wonder if i hit anything near the vicinity of the passenger side foglight to cause this. any ideas? thanks in advance.
#53
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Some night pics to see how the NOKYA bulbs look...
Here are some pics with the NOKYA ARCTIC WHITE bulbs. Eventually, when I change my front bumper, I'm going to go with yellow bulbs.
#54
2005 C200K Sports Obsidian Black on Black
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hello all,
Has anyone changed the front Fog Lamp bulbs in a 2005 C-Class. I believe they bulbs are H4's. If so, do you have any photo's of the proceedure and a description of what you did.
Thanks,
Thanks,
#56
Originally Posted by rlee02135
STFF.
you have to remove the panel in front of your front wheel.
just a few 10mm bolts and some push-pins.
then, reach under your car and take the bulb out.
Thanks for the help.
#57
Holy cow, that sounds difficult. I'm not going to use my fog lights as much anymore.
Maybe I can ask my dealer to do it on my behalf.
#58
2004 C32 ///AMG
Originally Posted by josephr
Thank you rlee02135. Are there any special instructions on getting the bulb out of the fog lamp holders themselves? Is it just a turn and pull out like the indicator lamps?
Thanks for the help.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
i think the bulbs are 9006's
#59
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
it's not that hard to do, I'm sure the dealers would charge a good amount of money to do this job for the retards that can't figure it out...
#60
Besides, some people have money left after acquiring this car unlike some people who have a nicer car than their manners. Or maybe it's just an LA thing? I hear that city turns people a bit meaner. I'll give you the benefit of the doubt.
#61
Hello all,
Thanks,![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Thanks,
#62
C55 ///AMG, 535xi
lol its not THAT hard, i just took out a few pins, and stuck my hand up and reached for the bulb, its hard at first, but when u get the hold of it, u'll be done in no time,
the first time i changed it, it took me about an hour to take the lamps out, but the second time, it took me 20 mins
#63
Super Moderator
Yea, I said "maybe". Besides, even if I did choose to remain ignorant, that doesn't make me a "retard".
and, going back to the cash issue that you love to belabor, for someone that isn't going to use their foglights b/c they fear replacing them, doesn't that give even more proof that your comment above to me is another contradiction?
P.S. I'm going to get to my point, I find you to be an annoying obnoxious newbie that has posted over 525 times in less than a couple months with nothing that has actually helped out in the boards. you restate the obvious and you play it off as if it's something new that you've discovered.
if you want, you can quiz a lot of people on the board that know me and have met me in person, I'm not a mean person, I just take offense to people who like to hear themselves talk but have nothing good to say other than restate the obvious.
#64
Some people don't like replacing fog lights, whether or not they can get it done at no cost or at cost, especially if it's so much trouble to replace.
I apologize about implying that you're a mean person, I don't know you and this is unfair of me to make this comment. Still, nice people can still do things that are not nice. Stating that a person who doesn't want to replace his/her foglights themselves as a "retard" wasn't the nicest thing in the world either.
Lastly, I might have overposted a bit on this forum. However, I think a reasonable percentage of my posts weren't that obvious. For example, I once stated that bi xenon lights shouldn't be repetitively turned on and off. You stated that had nothing to do with the "igniter" of the lighting system and only had to do with the bulb. But I could also state that it's obvious that turning the lights on and off would also put greater stress on the igniter as well.
How about this, since it's fruitless to have a constant debacle on the forums, and it does neither of us any good; why don't we start from a clean slate. I have nothing against you. I assume you are the same way with me. Clean slate. And I'll try to be more cautious about stating obvious things.
#65
No matter what, even though the 411 was posted on this procedure, people should still STFF before posting another thread of a topic that's been discussed several times. I'd bet a grip of money, if a person did an "advanced" search using the search key words "replace fog light bulbs", you'd find an older thread that could've easily helped.
#67
Holly Cow!
Did not mean to start world war III with such a simple question. Forums are learning places and places to meet people from all over the world and make friends.
Thank you all for your help and comments, you have helped me and I have learnt somthing about my car from this thread which I did not know before. I hope others have learnt something too!
Have a great day, be helpfull and not angry.
#68
a quarter mile at a time
Holly Cow!
#71
excites your girlfriend
the driver's side fog was a b****. i had to take off both the panel in front of the wheel and the panel just above the bumper to even reach up there, and once i got the bulb changed it didn't want to go back in the socket.
ah well its done. never again! haha...
#73
Great DIY pics as usual CT. You are trully back in full force and continually add the stuff that I was always to lazy to do...LOL.
btw...I'm merging another thread with this one. - drex
#74
#75
ctc230k, are these the ones you used?
http://www.xtremewhite.com/ORD-Light...20-1-1-1-1.cfm
