DIY Changing Fog lamp Bulbs & W203/CL203 Fog Lamp Thread
1 Post
2003 Citron Green C230KMT
194 city lights and the front turn signal depends on whether you have BIX or Halo's. 2356 is BIX turn signal. check out your manual, theres alot of helpful information in there. and its all indexed too. WOW!!!
Wow! I got the car delivered from New Jersey and my paperwork along with my second key and owners manual have yet to arrive and this is my fist benz so I am still getting used to most of the standard fitments they use. Ill make sure I take a look at it when it arrives?
I think this post would be pretty useless if I did have a manual? The ones I searched and found spoke of the 04 and wanted to make sure there was no difference
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Okay, so I tried to find the most recent and most relevant thread for this. I guess this is it.
I just replaced my foglight bulbs from the NOKYA arctic purple bulbs to NOKYA arctic white. Main reason is my left side foglight went out.
So I guess they didn't last as long as I thought they would, but since I bought the arctic whites, they look much nicer than the arctic purple bulbs.
I will post pics later on tonight, so you guys can get an idea of how it looks with the bix as well as how it looks with just the parking lights.
Eventually, this will all be irrelevant when I change my bumper (but that won't be for a while), so these will do for now.
Can I just say that the driver side foglight is such a pain in the a$$ to change. Passenger side is easy, but man. Such a freakin' hassle just to replace one foglight....LOL
A box on 4 wheels
Fog Lights
I swapped out the passenger side fog light, but im having a hard time reaching the drivers side fog light, any idea how? I took the bottom panel the one in front of the tire and tried reaching for it, but i can barely touch it.. help!
#32
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
I'm pretty sure you have to at least partially take the front bumper off.
I've seen it done a few times, quite a few screws, plastic grommets, and a metal bracket.
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
#33
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
#34
02 c240
in my experience, not as EZ and dachigga says. I needed a pivoting wratchet to adequately install the driver fog. the windsheild washer fluid resevoir gets in the way. removing the wheel well cover (with three bolts) is def the way to go. good luck
pm me if you need more specific info!
#35
Seemed pretty easy to me.....
#37
A box on 4 wheels
Okay just removing the 3 screws in front of the tire panel wont work, i thinking of removing some on the bottom. When i reach my hand in i have to go in a arc shaped and i can reach it with my pointing and middle finger to turn it, but thats not enough strength to make it turn and my thumb is stuck to this mietal thing..
#38
Are we talking bulb or the entire assembly here?
If we're talking about the entire assembly, not sure how much would be involved.
Just to replace the bulb, best way to do this is below the front bumper. Remove 3 or 4 of the push pins and you have to literally pul the liner out, so that it is slightly under the bumper. In order to do this, you'll have to push the bumper a little forward (don't worry. It's polyurothane, so it is flexible). After you do that, you should be able to fish your hand inbetween the liner and the front bumper to where the driver's side bulb is.
I believe there's another thread that has many recommendations on how to replace the bulb.
#39
uhmmm,
BUMP !!!
BUMP !!!
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
#40
yeah, if you want to just to remove the bulbs, than yeah all you do is remove the push pins.
If you want to remove the actual fog light, you have to remove the bolts, take out the pins and rip that whole panel out, the panel is like indestructable so after the pins and bolts, just yank the whole thing out, once inside, you'll know how to remove the fog light, it's just two hex bolts I think, can't remember, but I had to remove mine to put in my meshing. Didn't think of taking pictures for a DYI cause I idn't think it was that hard.
#42
If you take out the panel, then you have really short arms. But seriously, I meant, reach from the bottom of the car! remove the pins andpull the panel out from the bottom of the car.
#44
Originally Posted by Cappa26
which pins are you talking about? The ones that look like tabs? Do i just ply them out?
Remember, this is from beneath the front bumper, NOT through the front side of the wheel well. Locate the 3 push pins closest to where the fog lamp is situated. Those are the three that you'll have to pull out. Once you do that, you can pull the lining away and out. You'll have to push the bumper forward a little and pull the lining down until it is under the bumper. This is in order to create some space for you to fish your hand through. I found it easier after jacking up the car, but several people have done it without jacking up the car.
#46
c230 Kompressor Coupe
i used a flat head to take it out a little bit, then i just used my fingers to plop those suckers out. it took a while for the first two then it was simple afterwards. what bulbs are you replacing it with? what temp i mean?
#48
2013 c300 4matic, 2002 c240
Replacing them with JDM yellow Fog Halogen Bulbs =]
#49
Originally Posted by pookie
how much did you pay for these? i'm finding them for $70, a bit too much for a fog bulb.
http://cgi.ebay.com/ebaymotors/NOKYA...91700769QQrdZ1
NOKYA bulbs are pretty reliable. Good quality and not as expensive as PIAA's.
