reverse TICKING noise
Old May 18, 2006 | 10:35 PM
advans's Avatar
C55 ///AMG, 535xi
hey guys, i found this issue that i saw on B**world.
"Has anyone else ran into this problem. The specs are 2006 C230 auto. When in reverse and under 5 miles per hour, when you are tapping on the breaks frequently, it makes a sound as if metal is hitting metal. MB knows about this issue, but say it is normal use.
Does anyone know anything about this. Thanks in advance! "
and I have the same problem, its this loud metal "ticking" noise, I have no idea whats wrong. I the brakes apart, added brake paste, reinstalled the brakes and cleaned the rotors, whats going on!??
Old May 19, 2006 | 08:49 AM
aecasasus's Avatar
'04 C230K SS
Did you recently installed rims on it?
Old May 19, 2006 | 09:27 AM
djlight's Avatar
CLK 320 CDI Avantgarde 7g-Tronic
This is a normal brake sound. I have this "problem" on my benz and also in all the other car. It depends on weather, sunny and wet day and many other things.
Bye
Old May 19, 2006 | 04:21 PM
advans's Avatar
C55 ///AMG, 535xi
Bye
its there everyday, sun/rain warm/cold.... it bothers me a lot
Old May 14, 2007 | 04:31 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
So is this sound really "normal"? I just noticed my 07 doing this when backing in the garage. What is making the noise? Should I take it to the dealer anyway and see what they say?
Old May 14, 2007 | 04:34 PM
C24owner's Avatar
'08 E550 4Matic
It happens when I wash the car and back it into the garage. Dealer told me its normal. Since your under warranty, Id bring it in and have them look.
Old May 14, 2007 | 04:42 PM
advans's Avatar
C55 ///AMG, 535xi
It happens all the time now, especially after hard driving. I told my dealer about this a few times, but they didnt do anything about it.
Old May 14, 2007 | 06:16 PM
WaveyKat's Avatar
Something Slow
i get a tapping/clicking sound when i pull off or even when i step on the brake at low speed like under 5mph coming from the Rear sounds like the rear brakes..
Old May 14, 2007 | 07:38 PM
KleanC's Avatar
White C
oh man..this happens to me to all the timeee...i took it in to get it checked before i got my rims..they fixed it...then it happened again a week later..its not because of rims on the car..i havent had time to take it in yett...lets lemon our cars..
Old May 14, 2007 | 09:09 PM
johnand's Avatar
Super Moderator
That is exactly how it is for me too, only in reverse though
I will probably make an appointment for the dealer next month and see what they say, but sounds like this is a "normal" problem, as there are quite a few others that have this problem.
I may also take the wheels off and the rear and see exactly how everything is setup. I know the rear calipers are floating, so I wonder if they are moving a little and hitting something.
Old May 14, 2007 | 10:44 PM
advans's Avatar
C55 ///AMG, 535xi
well, I tried... taking off the whole setup, putting everything back. did a brake flush, brake pasted. but this happens still. but for me, on reverse only. after a hard drive. when the brakes get hot!
Old May 15, 2007 | 03:25 AM
DACHIGGA's Avatar
2002 CL203
I don't think that's normal, I've never had any ticking sound from the brakes while reversing.....
Old May 24, 2007 | 08:26 PM
WaveyKat's Avatar
Something Slow
anyone fix this yet,,,,this Chit is drving me Crazy.. am only hearing the noise from the Right Rear Wheel i get this click Sound once when Going Forward and Once When Reversing
Old May 24, 2007 | 11:14 PM
advans's Avatar
C55 ///AMG, 535xi
mike, PM me your cellie. i'll give you a ring tomorrow, see if saturday can work out!, im gonna be in NJ for the morning, mid afternoon. i always assume your in brooklyn area. so it would be possible for you to meet!
Old May 29, 2007 | 01:20 PM
WaveyKat's Avatar
Something Slow
so i took my rear Brakes apart over the weekend i took the capiler and Rotor off to see if anything or if any lugs was rubbing on the E-Brakes but i didnt see any sign on metal rubbing on each other i just can't find where the hell this noise is coming from. someone anyone please help well my car is going in for a Service B next week guess i will let the dealer do their magic.
Old May 29, 2007 | 01:49 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
I hear a noise from my front driver side, but it's because the tire touching the inner plastic cover. How do I know it's the rims? Cuz I had a spare tire when I was painting the rims, and it didn't make the noise.
Old May 29, 2007 | 11:27 PM
advans's Avatar
C55 ///AMG, 535xi
well, I have the stock brake setup and 17 inch wheels, this only happens on REVERSE and after the car is out for a crazy heavy throttle drive.
Mike, I sent you a PM
Old May 29, 2007 | 11:42 PM
gregr09's Avatar
non-MB
just got new rims and I'm getting a clicking noise from my rear, left wheel. Can't figure out what it is, but it doesn't sound too good.
Old May 30, 2007 | 12:00 AM
advans's Avatar
C55 ///AMG, 535xi
only when your braking, slow right?
Old May 30, 2007 | 12:40 AM
gregr09's Avatar
non-MB
Unfortunately no. Unlike your situation where you're going under 5mph, the clicking noise on my wheel increases with the increase in speed. I read on the forums it could be possibily be the length of the lug-nut and how it could be hitting something.
Old May 30, 2007 | 12:50 AM
advans's Avatar
C55 ///AMG, 535xi
what kind of wheels are you using? whats the offset of those wheels, and the lug sizes?
Old May 30, 2007 | 12:59 AM
gregr09's Avatar
non-MB
they're Mandrus Regenmeisters, 18x8.5 up front with a 32 offset and 18x9.5 in the rear with a 35 offset. Not sure about the lugs. I'm pretty sure the shop put the ones on that came with the wheels.
Old May 30, 2007 | 01:12 AM
SlvrC230SS's Avatar
is it possible maybe the lug is a little too long and hit the brake assembly?
Old May 30, 2007 | 01:15 AM
gregr09's Avatar
non-MB
that's what I'm thinking. Gonna find out tomorrow and post my results.
didn't mean to jack your thread, advans. just saw what you posted and coincendentally, i'm having similar problems.
Old May 30, 2007 | 10:50 AM
advans's Avatar
C55 ///AMG, 535xi
no prob bro, its better for more questions to be asked, and more solutions.
I think you need to add a 2mm space in the back. the lugs are probably slightly rubbing against your brake assembly.
