Intermittent light bulb problems
Old May 20, 2006 | 03:25 PM
petercrase's Avatar
2002 C230, 6 Speed, Bose Stereo, 6 CD Changer
Question Intermittent light bulb problems
My right front low beam headlight is working intermittently. I've changed the bulb and the problem continues. I had the same problem with one of the rear license plate bulbs, when replaced it was fine. Any similar problems out there? I have a 2002 C230K Coupe/Hatchback with about 60K miles. No modifications.
Thanks for any help.
Old May 20, 2006 | 03:50 PM
raymond g-'s Avatar
99 E320
Connections are always inherent weak points and should be 1st or 2nd items
to check. I'd suggest dbl checking the bulb connection for corrosion etc...
clean and squirt with contact cleaner, WD 40.
