1st problems!!!
......all sorted no problem...BUT...they have to replace my rear window because the radio problem is aerial related ( I guessed as much)and they also say the remote problem is also to do with the rear screen!!!!
....The pick-up for the remote is in the door,so what has the window got to do with it?????....I will ask them when they do the work,but any of you guys know?
....Do you think I have anything to worry about?.....bearing in mind I'm having a window replaced?
Window work usually isn't a big deal - the dealer should do a good job, I wouldn't worry about it.
Cheers, BT
the carpet lining up the rear wheel arch is not fitted too securely....
My car goes in next week for the drivers side door seal replacement and replacement of the windshield washer bottle filler tube/neck. They broke this during Service A and I had to point it out to them.
I will enjoy driving the 2002 E320 4Matic loaner.
Don't let them just put vaseline type grease on your seal. That was the first thing they did, and all it did was get my shirt dirty and the the interior with oily finger prints.
hope this helps...
If radio spotty and RF out for keys, then they are on the correct track to solve your problem.
Cheers
R
