Press The Gas Pedal but car doesn't move.
Old May 26, 2006 | 11:19 AM
The Punisher's Avatar
For some reason out of the blue my C220 is a sled.
I press the gas pedal and it goes nowhere. Like it has lost 90% of it's horse power. It moves just really slow.... Take forever to get up to speed.
The funny thing is that it happened as soon as I turned on the AC .... It just has not power, like the motor is not being fed or something...
Any ideas what these symptoms might insinuate?? Maybe Air Mass sensor? Throtle body ? Turbo ??
I am schedule to have the car into the mechanic on Monday but i was hoping i could kinda figure out what was wrong prior to that.
Cheers.
Old May 26, 2006 | 11:44 AM
advans's Avatar
C55 ///AMG, 535xi
I'm taking a guess that its ur Alternator,
When I had my maxima, I turned on the AC and it became a SLUG! and i later found that the Alternator had to be replaced.
Old May 26, 2006 | 02:45 PM
C240Style's Avatar
Mercedes is gone physically, but still in my heart.
Correct me if I'm wrong, but don't our cars have SUPERCHARGERS, not turbos? Unless I stand corrected, superchargers don't lag so I don't think that would be your issue.
Old May 26, 2006 | 03:35 PM
JDM's Avatar
JDM
2011 C300
Sounds to me like mass air or fuel delivery problem. does it rev? or do the revs just slowly accumulate? If it doesnt rev, try pumping the throttle pedal quickly at idle and see if the revs climb faster, this would indicate likely mass air sensor if they do. I would expect to see a check light on by now, although mine took awhile to trigger the light.
Old May 26, 2006 | 05:27 PM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Well, not all of them have superchargers...and some superchargers, not found on stock MBs, do require a bit of spooling like turbo's.
Erik
Old May 26, 2006 | 08:05 PM
eckc21's Avatar
05' C230K Sport Sedan
I do notice lag when I floor the gas pedal. I think supercharger still lags..not as much as turbe though.
Old May 26, 2006 | 08:11 PM
advans's Avatar
C55 ///AMG, 535xi
supercharger lags, but not as slow as turbo, but twin turbo is faster than supercharger.
as for the lag, when you do a Netural REV, does the engine "MOVE" or is it like a slow REV,
flip open ur hood, and REV it up, do you hear a "SUCKING" noise from the intake? if you do, i doubt its the Air Mass sensors.
and the car only lags with the AC is on?
Old May 27, 2006 | 10:58 AM
The car revs but it is a slow rev, it looks as if the car went into LIMP mode... Anyways taking it to benz on monday so I will find out then what the problem is/ was.
Old May 27, 2006 | 11:40 AM
advans's Avatar
C55 ///AMG, 535xi
when you figure out what the issue is, let us know, so if it happens to another one of us, we have a reference, thanks in advan-ced
Old May 27, 2006 | 01:19 PM
valdes's Avatar
05 C55, 01 C240, 00 Discovery
it could be your throtle body and a sensor in your trans
does it rev slow in park or in drive ?
Old May 27, 2006 | 01:27 PM
advans's Avatar
C55 ///AMG, 535xi
both park and drive
Old May 30, 2006 | 03:19 AM
ervg's Avatar
cls550 c218, s500 w221
had similar issue when the accelerator pedal sensor died. after flooring the pedal nothing happened for a couple of seconds and then the car accelerated - like massive turbo lag. I was told the drive-by-wire accelerator pedal has a backup sensor somewhere so its still somewhat drivable. anyway.. problem was solved after having a new pedal installed.
Old May 31, 2006 | 05:00 PM
Wanted to update you guys on the car problems.
Th reason the car was not reving/moving was because the inter cooler rad completely blew up, therefore the car could not built any boost. The rad is located on the bottom of the car and there is a good chance that supposebly i might have hit it somewhere which could have caused it to bust.
Anyways the rad was replaced and the car now revs normal again, however my AC now no longer pumps out cold air Is that rad in anyways connected to the AC ??? Like i mentioned this all went down when i turned the AC on and now that I no have cold air coming from the AC and the rad was replaced is leading me to believe that it might be somewhat connected.
Any ideas ???
