when should i get?
Old May 29, 2006 | 02:16 PM
FRISCO230's Avatar
when should i get?
what should i get my first oil change
Old May 29, 2006 | 02:20 PM
Buellwinkle's Avatar
When the car tells you too. Usually after 10K miles or about 14 months. Personally, I wouldn't go much past 2 years or 15 miles unless it was a lease vehicle. Because of this extended oil change interval, check your oil level frequently.
Old May 29, 2006 | 04:00 PM
white_w203's Avatar
is SOLD
your dealer should have kept you informed. otherwise service A should be at 15k.
Old May 29, 2006 | 08:49 PM
jan ken po's Avatar
'05 SS Brillant Silver
Just be sure to check to see if they use the fleece filter & 0w-40 oil during the change. If so, then you can round about another 10-12k tween changes. If they used then non-fleece filter & 10w-40 oil, then I wouldn't run past 5k.
non fleece filter part #271-180-00-09
Fleece pilter part #000 180 26 09
