Rain Sensor Aftermarket
Old Jun 6, 2006 | 12:38 PM
djlight's Avatar
CLK 320 CDI Avantgarde 7g-Tronic
Is possibile to install the rain sensor aftermarket?
How does it work?
Where is the sensor in C sportcoupe (behind the rear mirror?)
Old Jun 6, 2006 | 02:30 PM
white_w203's Avatar
is SOLD
im not even sure aftermarket rain sensors are available. i would recommend going with the factory part and installing it in the car to make it work effectively, but then again the factory rain sensor works "okay".
Old Jun 6, 2006 | 07:10 PM
rrpnow's Avatar
2006 C230 SS
yea its not worth the trouble...
Old Jun 6, 2006 | 10:22 PM
SUNILP's Avatar
2015 E250D
you can install a factory rain sensor. It is very easy to install but you will require a new windsheild that has the lens of the sensor mounted from factory. Perhaps a replacement for a cracked windsheild???
Old Jun 12, 2006 | 01:46 PM
Tishers's Avatar
'06 C350 4MATIC
Sensor
LOL, with SUNMAN everything is easy.
Wanna convert a gasoline to diesel? I am sure that sunny has worked out the details!
Old Jun 12, 2006 | 06:56 PM
TA-9FF's Avatar
One with 4 wheels
Yeah, ditto. I noticed when it rains, and the wipers are set on auto, I have to still manually click on the "quick wipe" occasionally because the stupid sensor sometimes doesn't know the difference between light and heavy downpour.....
Old Jun 13, 2006 | 10:08 PM
patrick_y's Avatar
2006 E55 and 2002 E320
Same here, I think i'm the third person.
The rain sensor works well but not perfectly.
And yes, you do need to replace the entire windshield ($1k I think).
And I don't know if there's any prewiring for a rain sensor.
Old Jun 13, 2006 | 10:43 PM
SUNILP's Avatar
2015 E250D
prewiring not required. Windsheild is more around 450 dollars. I just changed mine.
Old Jun 14, 2006 | 07:38 AM
MB-BOB's Avatar
Admin Alumni
See Garage
Windshields with rain sensor lenses included, can be installed for as little as $300 or so. See this thread for details... https://mbworld.org/forums/c-class-w203/150743-windshield-replacement-prices-fyi.html
