Where is your oil temp gauge at....?
Mine is a bit past the half way mark. I'd say around 90 degrees centigrade. Very important that it stays under 100 degrees centigrade since that's the boiling temperature of water. Naturally, since we add antifreeze and overboil solution to our water, the actual boiling point is around 125 degrees. But high heat will put greater wear and tear on the car.
