Pulley choices.
Yes, there have been 3 failures of SCs with the ring, tell me what was available other than the ring until recently on our cars? Also, remember that there are hundreds of people that are not on this forum with the mod that are not included in your sample size. I wonder how many SCs fail without mods, it would be no surprise if 3 is not out of the ordinary.
Again, read the links as it address' all of your points and shows where you went wrong.
can you take it apart? then you can see what is inside. take pics.
actually, better yet, take it to a metal band saw and cut a section.
I'm sure you'll find that thing is a harmonic balancer for sure. The weight is isolated from the rest of the pulley regardless of whether it's electrically isolated or not. I've got some flexable material here to show you that isn't an insulator. Continutity test proves nothing. If the damper isn't a damper...then what is the rubber there for? What's the weight there for?
Mdp c230k, the crankshaft twists as a result of the load on the crankshaft. The pistons fire and create downforce on the shaft, if the less the shaft can freely rotate, the more twisting is must absorb. The obvious load of course is propelling your car out the back end of the shaft. By introducing a heavy mass on the front end of the crank the twisting motion has nowhere to release so it creates a vibration. Reducing this mass reduces the twisting motion, how much is speculation but like I said, no failures to date. The opposite is also true, increasing this mass creates more twisting altering the natutal frequency, possibly beyond what the damper was designed for. One car has had the solid pulley for 80k miles according to Kleemann. As for s/c failures, Kleemann only made solid pulleys for the previous C230 sedans and SLK230s, no ring was available and that has been out for years, yet one of the s/c failures on an SLK used a factory pulley with a ring attached. I guess it's pick your poison, there always risk in modifying your car, I felt my risk was justified and reasonably safe or I wouldn't have done it. You must think the modification you are about to take is reasonably safe or you wouldn't do it. That's why there are choices.
You could always send me a factory pulley and I'll have my machinist cut it, but surely there's got to be an easier way...
If you look at the back of the pulley there is indeed about a 1/4" bead of rubber that fills that gap. On the other side of the ring it has a small lip that is pressed against the body of the pulley. There is no gap, at least one that you can stick a needle through. I could stick a needle through the rubber on the back side on the inside edge to prove that it won't come out the other side. I can use a drill to drive the needle in.
The 2nd link from mdp c230k's post has a graph (I name it Graph 1) comparing the vibration noises between a conventional pulley and a pulley with a damper. The pulley that contains a damper reduces the noise level significantly.
For a perfectly balanced pulley with no external force, there is no inertial vibration. However, there is force from the crank rods and the belts that will result in torsional vibration. Whether the pulley exists or not, the forces are always there and cannot be eliminated.
But the pulley is mandatory in order to drive the belts, and the forces will result in imbalanced loads on the pulley. The loads are magnified by the weight of the pulley and the rotational speed. The heavier the pulley, the higher the induced imbalanced load; the higher the rotational speed, the larger magnitude of the load (as seen on Graph 1).
So one concern in a pulley design is to reduce any additional loads created by the pulley. The goal is to "reduce" that addtional loads, not to "eliminate", because there cannot be a weightless pulley.
The rotational speed cannot be changed, so the only modification can be made or to play with the weight. For a factory designed heavy pulley, the weight is significant. This, in turn, yields the idea of a damper. The damper is to mitigate the weight effect (i.e., torsional vibration force) created by the pulley, but not to eliminate.
A super light-weight pulley with a damper is the perfect design, so the additional loads can be reduced to the minimum. But there is always the role of manufacturing cost, and this results in a heavy factory pulley with a damper.
Regardless of whether it is induced by a damped heavy pulley or a light-weight aftermarket pulley, a load is a load, and the shaft cannot determine where the load is from.
On one hand, you have the factory pulley with a damper, on the other hand, you have the after-market light-weight pulley with no damper. This is like remove conservatism on one aspect but add conservatism on the other aspect. The end result is two comparable designs. And the engine is already designed to handle that slight induced additional load by the pulley.
What my diagram shows is just a representative setup, which is modified from the pulley picture showing in mdp c230k's link to show what it would look like if that pulley is a press fit.
My diagram shows a typical net pulling force to show the theory only. It is not intended to accuratly represent the specific pulley design for the Coupe.
The pulley is pulling belts attached to about 10 other pulleys (I include idler and tensioner pulleys as part of that). Each of these pulleys as well as the belts themselves must introduce vibrations of their own. Don't these vibrations transfer to the crankshaft?
And, the governing force will be the one from the crank rods (this is the force being converted to drive the vehicle). I put the belt force just as an indication that there is some force from the belts, but not saying it is huge. (Note that Graph 1 does not even consider the belt force.)
Minor correction: I don't think the damper is pressed on. Instead, it's a close tolerance slip fit. This allows the damper to oscillate slightly yet is still retained radially. The slip fit also explains the continuity test. The pieces are actually touching, but are free to move relative to one another.
That's a good one, metal springs inside to conduct electricity. Face it, it's pressed on, metal against metal. I looked at it good with a magnafying glass in bright light and there is no gap what so ever between then damper ring and the pulley. Also, what happens when the rubber ages and gets harder, does it still dampen at the specified frequency? Why don't some cars have them at all?
I was instaling my ASP pulley yesterday (which I'll describe in a separate thread, a lot to be said about it). After the belts and the bolt were removed, the pulley wouldn't move when I tried to do it by hand, so I had to pry it off. In so doing, I could clearly see that the balancing ring moved with respect to the pulley body. This confirms that the balancing ring is connected to the pulley body by a rubber ring. This actually can be seen in the picture attached below.
This harmonic balancer acts as a rotational shock absorber. The diagrams shown in previous posts don't take into account rotational oscilations, but that's what this balancer is supposed to dampen.
Still doesn't answer the question of adding a ring to make it larger and it's affects on changing the natural frequency. And still doesn't prove that removing it has any ill side effects because nobody has had a crank or bearing failure in 5 years with the Kleeman alloy pulleys.
plus, i'm not going to keep the car for 20 years to worry about that real long term effect (does anyone?). so if a Kleemann alloy pulley doesn't fail in 5 years, that's pretty much the length i'm gonna keep the car.
I looked at mine again and it's touching. It could be a matter of tolerences. Yes, I admit defeat after seeing the picture.
