Passenger Kick Panel
Old Jul 20, 2006 | 03:58 PM
jgsx's Avatar
04 C32
I searched hard, but couldn't find this info on the forum. How do I remove the passenger side kick panel? I'm talking about the panel to the left of the passenger's feet. I'm also trying to figure out how to remove the inside of the glove box, that felty material.
Old Jul 20, 2006 | 04:03 PM
BadAssC230k's Avatar
"Double Stuff" SOLD | Nor*Cals "Pesky Audi"
if at first you dont succeed...
beat it till it bloody falls off!
Old Jul 20, 2006 | 06:36 PM
pshek's Avatar
2003 C-Class Sportcoupe
put your fingers underneath the top plastic part and pull down on the carpeting. i know it sounds stupid but it works. that's a quick way to do it. i saw steve do it this way. on the right side, there is a screw holding down a plastic cover, and it's also held in by clips. unscrew it, then pull off after you've removed the door sills.
Old Jul 20, 2006 | 07:29 PM
jgsx's Avatar
04 C32
I got that far, but I also need to remove the felt/plastic interior of the glove box. I also want to remove the hard plastic above the passenger kick panel.
Old Jul 20, 2006 | 08:38 PM
jgsx's Avatar
04 C32
What I'm really looking for is WIS: AR68.10-P-1400GM “Remove/install glove compartment”
Anyone have access to that?
Old Jul 22, 2006 | 12:27 AM
Moviela's Avatar
Ja, das nummer ist fur ein G wagon, weisenheimer.
What you want for a C32 is AR68.10-P-1400P
You need to remove the center console, the radio, several panels, and then the glove box comes out. Unless it was on fire, I'd leave it alone.
Old Jul 22, 2006 | 04:24 PM
pshek's Avatar
The hard plastic above the passenger kick panel is held in by torx screws, then it drops down.
Old Jul 23, 2006 | 10:14 PM
jgsx's Avatar
04 C32
I need it out. Do u have access to AR68.10-P-1400P ?
