Help with adding AMG Kompressor to C320
Old Jul 24, 2006 | 05:45 PM
moonikbenz's Avatar
Question Help with adding AMG Kompressor to C320
I found a great deal on a supercharger from C32AMG 2004 and was wondering if it’s compatible with my C320 Coupe 2005-year (W203). Is it possible at all to add the original compressor from C AMG model to regular C-class, if so what kind of problems to expect.
I appreciate any advice. Also, if anybody had business with Quality Auto Parts
http://www.qaparts.com, please tell me if it’s a reliable seller.
Thank you,
Andrew
Old Jul 24, 2006 | 06:19 PM
pshek's Avatar
2003 C-Class Sportcoupe
It will cost you a lot of money to get it to work. You will have to spend money on a new ECU ($1600), intake manifold, pistons, cams ($1200), practically all the internal engine components. That is because the C320 is naturally aspirated, and has 11:1 compression ratio, and C32 Kompressor has 9:1 compression ratio because of different internal components. If you slap on the supercharger without lowering the compression ratio, your engine will detonate and go kaboom! It probably wouldn't run correctly anyways.
You will end up spending alot more money trying to use the C32 AMG supercharger than just getting a Kleeman supercharger kit.
Old Jul 24, 2006 | 07:31 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Your account has been banned. We don't allow double identities.
