1.8 Pulleys
Old Aug 24, 2002 | 01:19 PM
Buellwinkle's Avatar
1.8 Pulleys
I took a brief look at the 1.8 motor at the dealer this morning and it appears that the crankshaft pulley is a single plane (1 belt) pulley. It also appears to have room to grow. My guess is that would be a cheaper pulley to produce than the 2.3L crank pulley, possible an under $200 item.
Old Aug 24, 2002 | 03:10 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Don't think it's possible with the single belt setup - with a larger crankshaft pulley you would overdrive not only the alternator, but the water pump and the A/C pump as well, which would likely be less forgiving than just the alternator (as in M111). S/C pulley seems to be the way to go.
Old Aug 24, 2002 | 03:21 PM
Unless is was part of a complete alloy underdrive pulley kit similar to what evosport offers on the V6 MBs. Then it may cost more but it would yield a few more ponies. Probably still under $500.
Old Aug 24, 2002 | 03:24 PM
vadim's Avatar
Yeah, but the A/C pulley has a clutch that can't be eliminated... Then it would be way over $500...
