Boost/Vacuum Gauge or Just Boost Gauge
2016 C63s AMG
Would it be ok to install a boost/ vaccum gauge on a supercharger car. It seems like 20psi boost gauges also come with vaccuum. 30psi is over kill for our cars. I came across this gauge for the Mini which also uses the eaton super charger. http://www.shop.com/op/~NMA3062_SUPE...51?xit_recom=1
c230k
2016 C63s AMG
Originally Posted by Benztecg
I have boost/vac. gauge and vac. gauge is important because if you know how to read it will tell alot about running condition of the engine.My normal reading is 20 inch/merc.
1 Post
2002 C230 Coupe(M111)
Get the one with the Vac gauge. Most of the time an engine operates on pretty high vac...think about it, its an air pump.
2002 C230K, 2013 BMW 328, 2015 BMW X5
Wow, sounds like your car has some SERIOUS POWER.
Do you have a dyno sheet for this car? How do you like the headers? I have a SuperSprint Res & Exhaust to put on, but I have been iffy on buying the header. What are your thoughts on this?
EDIT: Oops, I see the header as a future upgrade. What can you tell me about this two stage fuel delivery?
E
c230k
E
E
2016 C63s AMG
I just want to add a boost gauge. Why is there conflicting info. So my question again, all though it has been answered but my research explains other wise, is:
A) Super chargers do create vacuum, so you need a boost/vac gauge OR
B) Super charges dont create vacuum so you just need a boost gauge.
I've read that supercharged cars dont create vacuum. I am confused now. When do you actually get a vacuum reading on your gauge(driving, idling, etc...) Should my car also have a vacuum reading somtimes. Does the newer MP45 Eaton super charger have anyhting to do with it.
All engines create vacuum at idle, braking, cruising and partial acceleralation. Naturally aspirated engines at full throttle will see very little vacuum, turbo/sc engines will see boost at full throttle.
So yes, a vacuum/boost guage would be benefictial.
2016 C63s AMG
So does any one have suggestions on what brand boost gauge I should get? What ones are good to get?
I was thinking about the AutoMeter 3607. It lights up through the numbers and pointer just like our stock gauges in the dash.
http://www.egauges.com/vdo_ind.asp?T...r%20vise-versa
