Quick Question about nav antennas
Old Aug 31, 2006 | 01:16 PM
fanito's Avatar
02' C230k Sport Coupe
Exclamation Quick Question about nav antennas
If you guys have a navigation system, aftermarket or comand, where is the best place to install the nav antenna?
Tia
Old Aug 31, 2006 | 09:55 PM
CM208's Avatar
2005 C180K Sports Sedan
https://mbworld.org/forums/search.php?searchid=2022598
Old Sep 1, 2006 | 01:12 AM
Moviela's Avatar
If Mercedes installs a COMAND after delivery, they suggest mounting the antenna on top of the instrument cluster, under the dash pad. Easy trip for the wire down to the head unit from there.
Old Sep 1, 2006 | 06:33 PM
fanito's Avatar
no outside installation? I thought it was needed. BTW, I did STFF but I could not find anything relevant to the coupe... sorry
Old Sep 2, 2006 | 01:27 AM
Moviela's Avatar
I don't use an outdoor NAV antenna. I NAV on my laptop, and just toss the USB antenna on top of the dash. It works fine through the window. I use DeLorme Street Atlas software. It's only $ 80.
Old Sep 3, 2006 | 03:16 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the MB Comand NAV antenna is only long enough to mount under the top side of the instrument cluster or far end towards the front of the windshield.
aftermarket NAV if you get a Pioneer one they usually place it under the top dash vent.
There are no outside antenna needed.
Old Sep 3, 2006 | 05:33 AM
fanito's Avatar
Really? Will it work? I was thinking in the same place of my xm, which is the hood drain (the small rain pocket) but not always get the best reception. So under the top dash vent, huh? I would've never thought about that place, I'm wondering how is the reception. Thanks Frank
