Questions about new rims...
Questions time:
1) What is the weight of the stock sport rim on a 2005 C230 SS?
2) Does anybody know the weight of the 18' inch TSW Bremma's rim?
3) Is there a difference between the 2 rims posted below? (ASA ST4 and TSW Bremma's) If so, what are they? (opinions are welcomed) I did of course notice that the ASA ST4's rear rims has an offset of +32mm and the TSW Bremma's rear rims has an offset of 35mm. Does this not make a difference or is one offset better than the other?
4) Staggered or Not staggered?
A)
http://www.tirerack.com/upgrade_gara...5&autoModClar=
ASA ST4 Silver w/Machined Lip:
Size Selected: 18x8
Price: $199 (each) Closeout
Estimated Availability: In Stock
Recommended Tire Size: 225/40-18
Wheel Offset: 32mm
** Lightweight: 25.0 lbs. **
Size Selected: 18x9 Optional Rear
Recommended Tire Size: 255/35-18
Wheel Offset: +32mm
** Lightweight: 26.5 lbs. **
B)
http://www.sportcompactonly.com/prod...4&c=100013&l=2
TSW Bremma rims online with these dimensions:
Front:
18X8
Silver Machined Lip
5:112, 32mm offset
Rear:
18X9
Silver Machined
5:114.3, 35mm offset
Which one would you pick?Thanks in advance for any help/feedback!
Questions time:
A)
Size Selected: 18x8
Wheel Offset: 32mm
Wheel Offset: +32mm
B)
Front:
18X8
Silver Machined Lip
5:112, 32mm offset
Rear:
18X9
Silver Machined
Also, ASA wheels are good quality. They are made by BBS.
Does anyone know if we get any kind of special/extra discount from tirerack by being a forum mbworld/benzworld member?
EDIT: The rears on the Bremmas have the wrong bolt dimensions. You need 5x112.
I asked Luke @ tirerack if the ASA rims I mentioned in my previous post would fit on my stock 2005 C230 SS...and his response is below...
1) Will they fit my stock 2005 C230 SS without a problem and will they clear my front brakes? Yes, they fit with no issues
Not trying to prove anyone wrong here but I know you stated that these rims would not clear my front brakes...could luke @ tirerack be wrong?
Additional feedback from anyone would be greatly appreciated!
Just want to be 100% confident that the rims that I order fit my car...
Thanks!
Thanks!
Also, I have a friend with a clk who had the same rubbing issues with his ASA's after being assured by Tire Rack that they would fit.
more fitment issues... https://mbworld.org/forums/c-class-w203/105837-frustrated.html
Not worth the risk, IMO.
I wonder why for some people's AMG/Sports Sedan they fit...(such as rlee02135) and for some it doesn't?
I would like to get the ASA rims over the Bremmas because I heard they were much lighter / plus I don't see the Bremmas on tirerack...and if I buy the rims from tirerack I get the mounting and balancing included. (at least that is what is says during checkout)
But with all the good points that Blake P bring up I don't know...
Thanks again!
18x9.5 ET 35 Rear and 18x8 ET 32 front...
Fronts hit the caliper and the backs, besides the bolts being slightly too long, I'm worried about rubbing on the inner fender. With the car lifted the the edge of the rim is pretty close to the inner fender lining (no tires on the rims just yet). I obviously couldnt put the car down to check what its like at normal ride. Anybody's expert advice or experience would greatly be appreciated...
I cant get the wheel with a different offset for the front other than 32 or 45, so I guess I'm going to have to go with a spacer on that to get it away from the caliper. Dont want to but...
The backs... I dont know what to do!!! I dont know if they fit or not... Bolts not a problem, I can grind them down to fit. The wheel turns, but I hear a clicking noise which sounds like the thin metal gaurd behind the rotor so I would assume it is just barely touching.
TIA...
TIA...
for the rears, you can try to go with a 255/35/18 tire, like the Falken 452
The rear should fit if you don't go wider than a 255. I'm running 235 and with wheels 2 mm more out and they clear easily, but you're going to be out 8mm more than I am now with the 255.
If you want to go staggard, keep in mind that these cars tend to undesteer and getting larger rear tires is just going to make that worse. Yes the stock wheels are staggard, but this was for looks on the C230, more than anything else. If you are not into pushing your car to handle at its limits, it wont make a difference other than not being able to rotate the wheels.
The stock sport funnel spoke wheels weigh 22.5F/23.5R on my bathroom scale.
Anybody know where to get these damn things quickly?
