AMG bumper installation
Old Sep 15, 2006 | 10:44 PM
Ryanr317's Avatar
R129, XF Sportbrake, SC400
If i were to purchase an AMG style front bumper, OEM off of ebay, would i need any extra parts to make it fit to my 02? I read something about possibly needing some sort of bracket/reinforcemnt. Can i utilize anything from my existing bumper?
Old Sep 16, 2006 | 12:00 AM
benzmodz's Avatar
W203 slightly modified
It depends on the model of the bumper you have selected and what the seller is providing. If it is a skin you need an insert for the inner support.
Old Sep 16, 2006 | 01:38 AM
JesLet's Avatar
2002 c 240
X2....
Plus you need rivets/remaches to attach the "inner supprt"
Old Sep 16, 2006 | 02:31 AM
b3d_sage's Avatar
2001 C320 (purple), 2002 BMW 540i
make sure that you get the grills and foglights.
Don't buy one of those "repaired" bumpers off of ebay. It it's been cracked you don't want anything to do with it.
Old Sep 16, 2006 | 08:36 AM
SUNILP's Avatar
2015 E250D
You will need the alum rivets, inner support, 3 grills, fogs, and impact foam. Most can be reused from your old bumper. The inner support can be modified to fit as per OEM spec.
Old Sep 16, 2006 | 09:11 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
most amg bumpers sold on ebay don't include mesh grille which costs $$$ at the dealer...
Old Sep 16, 2006 | 09:34 AM
Ryanr317's Avatar
So then i can use the inner support from my old bumper wit modification? The one i'm looking at is just the skin.
Old Sep 16, 2006 | 09:36 AM
WaveyKat's Avatar
Something Slow
u gonna have a hell of a time trying to figure out which bracket/reinforcemnt goes with the bumper i heard there is a few different reinforcemnt so u must get the right one to fit the bumper. to make it easy try to find out which car the Bumper came off from and get the VIN number take it to your dealer and hopefully they can match up the reinforcemnt that came with the car. and thats the one u will have to get.
1. reinforcemnt
2. Foglights
3. 3pcs mesh grille
4. rivets
5. Clips for the grille i think u may need 12pcs
Old Sep 16, 2006 | 10:23 AM
Ryanr317's Avatar
I saw a few on there with the reinforcements already on them. I may save the hassle and spend the few extra dollars to get one of those.
Old Sep 16, 2006 | 01:24 PM
slammedcclass's Avatar
cclass05
what is the add on thing on the front bumper called i want to get one of those
Old Sep 16, 2006 | 06:19 PM
benzmodz's Avatar
Carbon Fibre lip ?
Old Sep 16, 2006 | 08:09 PM
WaveyKat's Avatar
Something Slow
license plate
Old Sep 16, 2006 | 08:11 PM
C240Style's Avatar
Mercedes is gone physically, but still in my heart.
Originally Posted by WaveyKat
license plate
Old Sep 16, 2006 | 08:12 PM
Ryanr317's Avatar
license plate
That's awesome.
Waveykat, Where'd you get your amg bumpers from, and about how much did they run you.
Old Oct 12, 2006 | 03:54 PM
Ryanr317's Avatar
If i were to go ahead and get one of the bumpers off of ebay without the headlight washer holes, would i be able do just cut them in there?
Old Oct 12, 2006 | 04:35 PM
rlee02135's Avatar
2004 C32 ///AMG
nope. there are hinges on the bumper that lets the washer arm come out
Old Oct 12, 2006 | 06:39 PM
Ryanr317's Avatar
Hmm, so i guess there's no way to retrofit them on?
Old Oct 12, 2006 | 06:44 PM
rlee02135's Avatar
2004 C32 ///AMG
not that i know of
Old Oct 30, 2006 | 08:46 PM
Ryanr317's Avatar
Would theses aftermarket AMG style bumpers also require the AMG reinforcement? The body kit stores that have the aftermarket ones don't say anything about the reinforcement, nor do they include any type of reinforcement.
Old Oct 30, 2006 | 10:17 PM
rlee02135's Avatar
2004 C32 ///AMG
dont know much about the replica kits, but try it out...if it does require one, whats an extra $200? you saved that much alone by not buying a real AMG bumper. some replica kits come with the grills, too, which will cost over $300 at the dealer
Old Oct 30, 2006 | 10:37 PM
Ryanr317's Avatar
Yea, that one comes with the grill, but no holes for the fogs. I may have to cut them out if i were to go with that. But it looks the same as oem, so i'm thinking it may require that reinforcement, but then again i could be wrong.
Old Feb 6, 2007 | 11:00 PM
Ryanr317's Avatar
Does anyone know if the AMG rear bumper also needs it's own reinforcement like the front does. What about impact strips?
Old Feb 6, 2007 | 11:35 PM
coin's Avatar
'06 CLK500
I think you can use your C320 bumper reinforcement or at most you have to modify it a bit.
But I am pretty sure the impact strip is similar to that of C320 bumper.
Old Aug 7, 2007 | 07:55 AM
reznor9's Avatar
2003 C230 SS
Need help facelifting my 2003 C230 SS
I just purchased a 2003 C230 Sports Sedan last month. The first thing I wanted to swap out was the ugly frosted headlights which I did finally and the car looks 100X better already I also was lucky enough to get the rims swapped out with a 2007 c230 which are pretty bad ****. I have a few questions on what else I need to give it a complete facelift and if anything requires any body shop modification or is it all stuff I can install myself?
My main concern is that I want to install the AMG style front bumper like the newer 2005-2007 have, and Ive seen some for sale on ebay but dont know if this is just a direct remove and replace part or if other parts have to be replaced as well or modified to fit. Any input would be appreciated.. FYI, I did use the search function but didnt really find the info I was looking for... but found some great DIY on how to remove the bumper.
Other than that I plan on getting the lip spoiler, replace the frosted fog lenses with some clear ones, facelifted side mirrors and possibly a flat hood emblem and CL or Expressions grill.. but not sure on the grill and emblem though, I kind of like the elegance the stock hood emblem gives the car. Are there any other suggestions anyone has? Thanks
Old Aug 7, 2007 | 11:02 AM
kevblah's Avatar
E90 M3
stff
